neverfinished52 Posted January 11, 2017 Report Posted January 11, 2017 I have a 52 Chevy pickup and I was planning on doing the Big 3/4 upgrade. The current wiring is hacked and I think it may be wise to just replace the battery cables completely instead of just adding to it with the Big 3/4. Has anyone replaced their existing battery cables with wire intended for car audio or should I go with welding cable? I want to do this right and l just purchased an Optima Battery so I want new terminals as well. Any thoughts, suggestions are greatly appreciated. Here's a quick pic of my truck
ShadeTreeMechanic Posted January 11, 2017 Report Posted January 11, 2017 If it were me, I would use welding wire. Car audio wire is not created equal. The temperature rating on welding wire is excellent and car audio wire is hit and miss. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
WalledSonic Posted January 11, 2017 Report Posted January 11, 2017 Badass truck man. Other than weld cable, you can also select a higher voltage wire from a local electric supply. A lot of 600V or 7500V cable is oil resistant (look for <1.5% absorption), 150degC insulation, and is more rugged than even weld wire. If you are using it under hood, I recommend tin plated copper, not just OFC. Im using Champlain 7500V EXAR wire for my underhood power and ground cables. For my run to the rear bank, however, I'm using 105degC KnuKonceptz. Post some more pics of that sexy thang! Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
neuspeedescort Posted January 11, 2017 Report Posted January 11, 2017 i've done a few big three with factory replacement setups. never an issue. just don't skimp on cheap wire. buy good stuff. lug it properly tuck it like factory to make sure no melting or chaffing happens.
soffhands Posted January 11, 2017 Report Posted January 11, 2017 i would use welding cable for everything battery and car audio
Smoove Posted January 11, 2017 Report Posted January 11, 2017 Stop, just stop. Regular OFC 1/0 is probably more than efficient this ride. You people crack me up with your welding cable for a 240amp alt at 6000rpm 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
Smoove Posted January 11, 2017 Report Posted January 11, 2017 And I am betting the OP is a troll. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
neverfinished52 Posted January 11, 2017 Author Report Posted January 11, 2017 Thanks for the suggestions. Found a couple sellers on ebay with good prices on welding cable. Any suggestions on battery terminals? I've always used knukoncepts in the past. Here's a quick pic at work with my new chrome grille. Needs a bath
neverfinished52 Posted January 11, 2017 Author Report Posted January 11, 2017 Oh yeah, will I need to fuse any of the positive cables? I know some cars come with a fuseable link (although I'm sure mine didn't back in 52)
Skullz Posted January 11, 2017 Report Posted January 11, 2017 Top post terminals. http://www.ebay.com/itm/NOCO-TZKIT3-Lead-Free-Military-Grade-Zinc-Battery-Terminal-Kit-New-/162295260083?hash=item25c98d23b3:g:~XkAAOSwpDdVWdt0&vxp=mtr Select the wire size you want and length. http://stores.ebay.com/TEMCo-Industrial/Welding-Cable-/_i.html?_fsub=3792388011 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
