3 or more amplifiers install help
bluegmcjimmy
Ok this is a noob question, how do you stall 3 amps or more safely?
https://www.youtube.com/channel/UCWd1ShRnPbDG9ppgJKpumdA <---- show some love to my channel
Alpine MRH-F255 (old school), sub channel not used
Skar audio VX35-ST tweets in front  (invest in them they are worth it)
kicker zr120- nice underrated amp
Powerbass s1204 subwoofer in a 1.75 custom slot ported enclosure tuned to 30hz
Front doors Prv 6mb200s 8ohm
Alpine type-e 5.25 in dash took a shave and a hair cut.....- not in use
Rear doors alpine 6.5's model/series unknown but they are loud as hell
Factory alt
3.5 farad cap, does the job for now.
Deck is a pioneer mixtrax 700bt model
And my baby my Pioneer EQ-6500 i got for 10.00
Back-up amps- Ma Audio 598i, kicker zr120, my highly under rated JBL LC-A502 1xx watt amp...
On the side- Quantum tweets not yet installed
Distribution power and ground blocks. Fuse holders or distribution fuse blocks or circuit breakers(easy and quick way to cut power to ur amp, just flip the switch). Also i just learned its a good idea to have a relay to wire ur "remote" amp wires to, so they all turn on at the same time. Theres probably other ways to wire the "remote turn on wire" but thats the cleanest way i think.
A relay doesn't make them all turn on at the same time, a relay lets you use a secondary power source when the remote wire isn't enough. Not needed typically with 3 amps though.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Imagine a power wire from your battery that you connect to a switch, you flip that switch and it turns the amps on.
A relay does just that, except the switch is engaged with a 12v source instead of your finger.
Note: it's not a switch like you are used too, just using that to explain what it does.
F150:
Stock :(
Processor: DSR1
  • Who's Online   1 Member, 0 Anonymous, 1800 Guests (See full list)
