The sound wont come out if both sides are sealed
EDIT: c'mon man...
IG @walledsonic
Lmfao.
Cone control would be better at 4 ohm. Normally as you wire down, the damping factor goes way down too. How much is needed I don't know. When I wired my amp at 2 ohm, it sounded good but I couldn't drive it hard enough to get loud and sounded like crap when I tried. I wired down to .5 and the power is more than enough and I don't have to max it out to get loud. I think having power on tap without maxing out would be better and easier at low ohms than trying to make power at 4 ohms.
Pioneer 80PRS
One would assume that the power loss do to impedance rise would be very similar between the two amps seeing as one is meant to make its power at 1 ohm and the other at 4ohm, its not like he was asking about wiring the amp that does 2k @ 1 ohm to a 4 ohm load.....
There would be multiple benefits to using the one that makes thr power at a higher ohm load, but also there would be some cons such as the cost of such an amp.
If its a sub amp you may or may not notice a difference, if its mids and highs youll for sure notice a difference.
I feel like the only con in the bass amp portion, would be price. Your at a higher ohm load, so higher efficiency to make the power, meaning less eat is created. Higher dampening factor compared to 1 ohm.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Another con is size, especially if its a class ab amp making that kind of power at 4ohm.
