Simply based off the melted fuse/holder, and the possibly 8ga wire,  I'm guessing you didnt have the electrical capabilities to support the current draw of the amp. Use larger wire for both the amp posistive and negative, make sure your fuse in and out are SOLID, and double check your ground to make sure its got a really good connection to some beefy metal of the frame/unibody. Probably should throw the big 3 in there while you're at it, just to cover your bases power wise.
It is a 3000 watt amp so should I use a 2 gauge wire to get better power. It's a 4 gauge wire right now. And if I do that will it stop my interior light from flickering? It's the color changing lights that they started putting in the newer ford models. And the compass is all messed up and keeps saying error, telling me I'm goin north or it will say compass no response. That part i thought was maybe loose connections on the radio harness I went back and rewired all that and it still says the same stuff and lights still flicker. I hate wiring into factory stereos for this exact reason.. custom setups are easier but all the nav and stuff is hooked in to the radio so my car would throw error messages all the time. Sorry the the long response
>BOSS AMP
>not really 3000W
>shat electrical
Rewire with 1/0, do the Big 3 upgrade, and get yourself a better amplifier.  I owned a Boss, so I can honestly say that it doesnt put out the RMS power.  Mine lasted 2 days until it stopped working.  No protection circuit.  No internal components visibly burnt.  Just stopped working.
IG @walledsonic
to wire into the factory system all you need is a good line out converter.  I recommend the DB Drive HLC-4R.  all you have to do is grab an audio signal and give it 12 volt and ground.  once connected it creates a remote signal from the mix of the power and the audio connection you tapped into.  I will never use another converter again unless they come out with one better.  but doubt it.
change out you line out converter and also get a better amp.  usually on the boss amps you can drop the last digit and that will be you power.  lol.  get a good used amp from a member on here like a saz-1500d or a DC1.2k or even a DC2.0k.  will not require the addition of another battery (is ice to have) but not needed with proper wiring and the big 3 upgrade.  as for the light flickering well thats going to happen when you have a current draw. (aka amp and subs) unless you have additional batteries to support the voltage drop.
1. Don't be afraid to ask a question or for help.
2. Get better converter
3. Get better amp
4. Get better wiring.
I started off with a kicker 300.1 and 2 kicker svc 12s several months later i realized that they are ok but damn my re audio, DC and Sundown were a lot better.
spend the time to invest in quality products and you will not only be happy but realize that the cheap shit is just that cheap shit.  and dont let what happened to some guy at texas showdown happen to him  rushed the job got shitty equipment and shitty install and burned his car down to the ground while waiting in line to get in.  "from what I heard about the equipment and such)  I didnt see it the install  but did see the car blazing.
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
6 hours ago, WalledSonic said:
>BOSS AMP
>not really 3000W
>shat electrical
3. Get better amp
Ok I went back through everything. I have a Pac loc 7 for my converter. The amp is working and actually goes into protection mode once I really turn the bass knob up. I have 2 12 p3d4 rockford fosgate subs. I blew my radio fuse just a lil while ago from turn the loc volts up too much. And with my lights, they are coming on and off and only the blue light makes my system work. It's the led lights that light up the floor boards not my dome lights. They don't flicker at all. And amp wise would a rockford fosgate amp be a good choice?
I would not buy another thing until you fix your install.
Pioneer 80PRS
I got everything squared away except my ambient lighting is not working (might have to replace a fuse maybe) and the compass navigation feature isn't working
  • Who's Online   0 Members, 0 Anonymous, 4447 Guests (See full list)
