Help with first aero port box. Skar DDX 15
Pu61ic3n3my
So to start out this box will be going into the trunk of a 2005 chrysler 300c. Sub is a Skar Audio DDX 15 being powered by a matching rp 800.1 and max dimensions are: 17H x 31W x XD (D = anything really to make 4 cubes and fit aero port inside box if Possible). I already have a 4 cu ft slot ported box in the back with sub and port facing into the cabin, and it hits nice but i like the look of aero ports plus a change is nice every now and then.
Now my question's really come down to: Sub/port placement ( IE: sub up port back, sub/port forward, sub back port forward) and what size aero port(s) should i go with? Looking for around the 32Hz range.. Also is there any advantage in having the length of the port inside the box vs outside?
Welcome to SMD. A six inch port might work with that power, but I would really use an 8. The only reason for an external port is because it won't fit in the box. Maybe @Triticum Agricolam can help.
Pioneer 80PRS
No subs up in a trunk car, I would recommend subs / port forward sealed off or subs / port rear firing (you could try that with your current box), as for the port size 6in is on the limit for that sub in a 4 cubic feet box, it may work but likely a properly sized slot port will do better.
  • 1 month later...
10 minutes ago, Kingnolan said:
I’m looking to build a similar box for my zv3 15 any recommendations I want to go with an aero port as well it’s getting about 1400 rms
I suggest an 8" aero port, it will have to be long.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 1703 Guests (See full list)
