looking at the sundown zv line an seen the low bl an high x max an low fs ?
camshairtricks
ok im looking at these subs an couldnt help but notice these specs . they have a low bl didnt expect that for such a big motor any way how can these subs control the cone at a high x max 30mm an a low fs wouldnt they sound muddy an lose cone control above 28hz ? i mean i seen the bl was under 20 aint that a weak motor force . my evl has a tiny motor compared to the zv4 yet the bl is more than the zv4  i no the gap plays a role in bl but still . ?
As you move up in frequency cone control becomes less and less of an issue since above resonance, the cone doesnt need to move as much.  The sub doesnt see Xmax above tuning, usually, unless the enclosure design is completely jacked up.  From your previous posts, we gather that you want a low tuned setup.  The sundown products (along with many others) are industry proven to get low and still sound good.
Have you tried modeling software like WinISD, BassBox 6, etc?  Theres a lot to learn in the enclosure design software.  The TS parameters dont mean much on their own... once you design an enclosure for the sub, thats when the TS parameters become more meaningful.
IG @walledsonic
How old are you?
IG @walledsonic
2 hours ago, camshairtricks said:
i can push my sub to max excursion at 37 hz im tuned at 30hz
what is your bass boost at? it tends to deform things around 40 hz
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
Two threads with the same question. At least someone can still get trolled here if they didn't see the other one....
Pioneer 80PRS
17 hours ago, zack_e89 said:
Too bad you got here after the Kranny rule. I think only a few will know what I'm talking about but I don't care.
In Kyle form, "Nothing to see here...nothing at all...move along now..."
I miss seeing Kranny around here... good thing he is not actually that far from me and I run into him at Slamology every year
