Cut sheet confirmation, please (thread title edit)
Markous
Looking for some help drawing up a cut sheet for a box i'm going to be building in the next few months. Rather than me trying to draw the cutsheet and end up fucking something up i thought i'd ask you helpful and  kind folks here :asskiss: for something in a sketchup type view.
Like to have a plan now so when the time comes in a month or two it's easy for me to give to the folks doing the cutting for me at a local Rona hardware store.
This is the side view of what i 'd like to build,
The width i figure will need to be 33". I plan to have the sub up and invert the PR's out the sides and between the negative displacement of them and the cutout i figure it will negate the volume required for the subwoofer and dowel bracing i plan on using.
The notch in the one corner is so it fit's around a structural support in the cab of my truck as seen here with my current enclosure, i had to shape the edge under it to fit the angle using a tri-square ruler which worked surprisingly well.
Like i said before i could probably draw it up myself but would like something in a sketchup type view so i don't hand the wood cutter a mess of a drawing.
Many thanks in advance SMD box guru's
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
there's an extension you can download for sketch-up called CutList that will do exactly what you need/want, if you already have your sketchup design saved/built
The fact that i even posted this thread has been bugging me all day, it was a moment of laziness that in the time it took to post i could have figured out myself.
I intend to use 1" mdf and this is the cut list i created, the cut sheet should be as easy as taking the 31" peices out and then the sides out of the leg left behind from that .
72B2E947-1420-4150-996B-ABD7C324517A_zps
Would this be the wisest way to do it? how would anyone do it differently?
Here's what I have:
The external width of the box would need to be 32.2" for the gross internal volume to be 4 cubic feet.
14 hours ago, Markous said:
....I intend to use 1" mdf and this is the cut list i created......
My back hurts just thinking about that.....
Builds:
Thank you for that picture Joe, much appreciated!
TA,the box i have in there now is built with it too.
Between it and that 15 i bet it's around 200ish lbs.
I put the sub in after i bolted it to the cab though.
Unless you have a bunch of 1" on hand I would just do 3/4" with bracing you will not have any issues.
It's available at a Rona hardware store 5 minutes from my place, they do my cutting for me there too.
Pretty handy for an apartment dweller like myself.
Tuned in for PRs!
IG @walledsonic
  • Who's Online   1 Member, 0 Anonymous, 2162 Guests (See full list)
