Pioneerchuck Posted January 28, 2018 Report Posted January 28, 2018 Alright so I am currently looking for an OBD2 dongle with wireless capabilities so I can "stream" it to my screen in the vehicle. I am looking for one that does tach, speed, mixtures, codes, etc. If anyone has some great recommendations on which to use, Id appreciate it.
Skullz Posted January 28, 2018 Report Posted January 28, 2018 You can get one of these or go on ebay and get any OBDII scanner with wifi, or apple with bluetooth. http://www.palmerperformance.com/hardware/index.php I use dash command and got one off ebay, it took a second try from ebay as the first wouldn't connect. EDIT: ELM 327 is what you want off ebay. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
MünürYılmaz Posted January 28, 2018 Report Posted January 28, 2018 This works perfectly fine for me https://www.amazon.co.uk/Goliton®-Bluetooth-Compatible-Android-Support/dp/B009NPAORC/ref=pd_lpo_vtph_263_lp_img_3?_encoding=UTF8&psc=1&refRID=TC7FE11PMTD8SNRAFC7E
mothra Posted January 29, 2018 Report Posted January 29, 2018 what it reads will depend on what the vehicle monitors through OBD. you could use a Maestro RR, but again it's limited to what your vehicle reads through OBD. if nothing changes, nothing changes You don't know what you don't know, till you don't know
Markous Posted January 29, 2018 Report Posted January 29, 2018 My iphone wouldn't play nice with the ELM 327 bluetooth version had to get the wifi version to use the EngineLink app '07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I On 5/21/2015 at 7:07 PM, boom50cal said: of course he gives no fucks. it's a ford ranger. only bad mother fuckers drive ford rangers
Pioneerchuck Posted January 31, 2018 Author Report Posted January 31, 2018 I am mainly looking for tach, speed, voltage, and ratio's. All of which Im able to read with my Launch CRP Pro. So I know the computer has the parameters to show. I'm just looking for a good wireless dongle or whatever everyone calls them, to install in the truck permanently. Ill check out ELM327 and see what I find.
PC Principal Posted January 31, 2018 Report Posted January 31, 2018 On 1/28/2018 at 12:27 PM, MünürYılmaz said: This works perfectly fine for me https://www.amazon.co.uk/Goliton-Bluetooth-Compatible-Android-Support/dp/B009NPAORC/ref=pd_lpo_vtph_263_lp_img_3?_encoding=UTF8&psc=1&refRID=TC7FE11PMTD8SNRAFC7E This is also what I use (actually a very similar device). I have an android tablet with the Torque app installed and I can read any information that the ECU produces. I am able to clear engine codes as well with it. Its a very cheap solution. 2007 Toyota FJ Cruiser RF Power T1000 BDCP RF Punch 400-4 2 P2D4 12's
Markous Posted January 31, 2018 Report Posted January 31, 2018 33 minutes ago, Pioneerchuck said: I am mainly looking for tach, speed, voltage, and ratio's. All of which Im able to read with my Launch CRP Pro. So I know the computer has the parameters to show. I'm just looking for a good wireless dongle or whatever everyone calls them, to install in the truck permanently. Ill check out ELM327 and see what I find. The app i use doesn't show voltage '07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I On 5/21/2015 at 7:07 PM, boom50cal said: of course he gives no fucks. it's a ford ranger. only bad mother fuckers drive ford rangers
MünürYılmaz Posted February 1, 2018 Report Posted February 1, 2018 13 hours ago, PC Principal said: This is also what I use (actually a very similar device). I have an android tablet with the Torque app installed and I can read any information that the ECU produces. I am able to clear engine codes as well with it. Its a very cheap solution. I use an android phone for exactly this reason it works very well for me as I'm able to monitor all sorts of sensor and investigate and clear any error codes my ecu spits out
Pioneerchuck Posted February 6, 2018 Author Report Posted February 6, 2018 Thanks guys, I appreciate all the help. I wound up going with the Dash Command app and 1 of the inexpensive adapters. It was able to read voltage and all parameters I was interested in.
