Strapped AudioPipe APCL 18001D's ok to run at 1 ohm?
i3laine
I've got a single AudioPipe APCL 18001D that I had pushing 2 Sundown SA-12's. Over the weekend I traded my 2 SA-12's for a single ZV4 12. The single amp isn't enough to push the new sub. I was thinking about buying another amp and strapping it to push the the new sub. The problem I'm facing is that the Audiopipe amps list a strapped minimum impedance of 2 ohms and the ZV4 12 is wired to 1 ohm. My question is this: If I strap the 2 amps @ 1 ohm, could I turn them down to around 2500 watts rms so that the amps are not being pushed too hard?
I wouldn't go past what they are rated for from a company like that. Sundown/DC/Crescendo, sure they would probably be a different story. I would strap them at 2 ohms and get yourself just past that 2k range.
Alpine cde143bt/ Alpine ktp445u (4x45 amp)
2 Crescendo STS 1 (on alpine 4x45 on 2 channel mode)
4 Crescendo pwx 6.5's in front doors (Skar RP150.4)
1 Sundown zv3 12, SAE1500D.
Box is 2.5 cubes tuned to 30hz.
I would not do it OP.
You could turn the gain down on the amplifiers leaving headroom in the future, provided of course the gains are all set appropriately, but I just wouldn't run those boards at 0.5 ohms each in a daily set up.  You can, and they made handle it, but they may also go up in smoke in a week or a day or two months, even if you have good electrical and can keep voltage up.  Good luck whatever you choose.
I'm asking because i don't remember but isn't the AP 3000 like actually 2 boards already strapped together internally which kind of doesn't allow you to run at lower ohms or something?  I don't know if the 1800 is the same way or not.
Many of us have been in your dilemma.  The easy answer is get a different amp, but it feels financially inefficient when you already have a amp.  Ohm load can be a fickle beast IMO. If you ever upgraded you amp, then eventually you will upgrade you subs and be back in this predicament.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
That trade was a bad decision all the way around, the only upside is the bragging rights to say you have a ZV4 12".
You lost 1/2 of your cone area in one move, and compounded it with a sub requiring more power.
Your best move would have been to get a 3k amp to power those SA12's, and if and when the time came for an upgrade, it would put you in a much better position for the upgrade without requiring another amp you do not have.
Not trying to come off as a dick, but some times we all need those life lessons.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
On 5/8/2018 at 12:15 PM, bmwking said:
if youre going to get a matching amp, just wire each amp to each coil of your sub, gain match with a dmm.  that will be less stress on your electrical and the amps.
This is possible? I didn't know that. Interesting
  • Who's Online   0 Members, 0 Anonymous, 1296 Guests (See full list)
