My instagram: https://www.instagram.com/joshdashef1/
Most updated pics can be found at https://www.tumblr.com/blog/joshdashef | I use Tumblr as my picture hosting platform |
Previously I had a RF Prime 750.1 going to two RF 12 4DVC on stock electrical and big three.
New Build Equipment
Active Setup from HU: Pioneer 80 PRS
Front Stage
T2652-S powered off a P600X4 (4 ohm | speaker per channel)
Lows
2x P3 4DVC Sundown SA12s (soon to be Fi SP4v2+ 15") powered off a DC Audio 2k (1 ohm | Dual 1/0 inputs) (to be replaced by AAK 4000.1D)
Batteries
Starter - XS D5100R (Flat 6 Bolt)  Walmart Group 51R | Reserve - XS D3400 (Flat 6 bolt)
Alternator
Mechman 240 Blue
Wiring
RCAs - Rockford Fosgate 20ft | Sky High 1/0 Blue (2 runs) | Sky High 10 gauge (subs) | Front Stage Speaker Wire - undecided matching Sky High 14 gauge
Fuse Holders / Gauges
Blue Seas Analog Volt Meter | Stinger Volt meter (red) | Sky High dual anl fuse holder (two for main power and one for sub amp input) | SMD Fuse Blocks 3x dual 1x single
Planned Upgrade List
3 pairs of RCAs  Done
New Wider False Floor Not needed
New Sub Enclosure 2x12 or 1x15 DONE 2x12
Amp Rack for Dc 2k and four channel Done
Distribution Block/Fuses (trunk) Done
Dual Fuse Mount under hood  Done Replaced with SMD dual fuse holders - Thanks audiofanaticz
Running two runs of 1/0 Sky High OFC front to back Done
Battery Mount for XS D3400 Done
Mechman HO Alternator Done
New Headliner
New Rear Parcel Tray or Reinforce old?
Fix Gas Lid Wire  Done
Stinger Volt Meter for front and rear batteries Done
Treat doors for new mid woofers Outer skin treated, need to cover holes with thick metal sheet and rivets
Run speaker wire for mids and highs Done
Install train horn in rear bumper  Done (Now I want to add one to the front bumper)
Setup LEDs above amp rack Done
Install distribution block and run +/- 4 or 8 gauge for it. 4 gauge +/- Done
Sound Deaden areas;
Doors (outer skin middle 1/3 done and focus directly behind speaker)
Roof
Wheel Wells (partial coverage)
Trunk lid (lower 1/2 done) (Outer panel 3/4 done)
Trunk spare tire (1/4 done)
Parcel Tray
License Plate (Full coverage with foam around it)
Head Unit: Pioneer 80 PRS
Amp:
Subs / Old Q-power Box:
Under Hood:
Day 1: Strippin 'er down
Trunk
Cabin | Rear/Front Seats Removed and some panels including center console (didn't get a pic of rear seats will do tomorrow)
For those who have had their gas lids go out on their Civics this may help you out.
Sometimes they go bad near the key barrel because of a plastic piece but in the case of my civic coupe I had a metal connection that was crimped over the wire. The actual issue came with the rear mechanism near the driver side brake lights as shown here;
The fix is simple really as you just need to stop the bottom connection with the crimp from moving away from the plastic mechanism. I did this with zip ties but you could easily do this with a number of supplies like hose clamps etc. without the need of running a whole new cable!
Ended up running the RCAs, remote turn on, bass knob, and deadening some of the spare tire well.
My trick for looming up multiple wires - a semi loose zip tie
RCAs
Fuse Holder
Bass knob and remote turn on
Sound Deadening (temporary / plan on adding more to problem areas after I am able to test bump system)
My 1" unibit and Dd-1 came in today! Was able to plan out the power run and drill the two holes in the firewall. Gonna run the wire tomorrow morning to both fuse blocks. Then get to work on the grounds.
6 minutes ago, Joshdashef said:
Got the power wire done today but have some issues with my fuse holders... might be upgrading to SMD dual fuse holders!
I like the way you wrapped the wire, almost makes it OEM looking. Looks clean man, keep it up ?
1 x Wolfram W-4500.1
2 x XS Power D5100's
250A Singer Alternator
2.67 Cubes @ 29hz
Got my component set and amp.
Birth sheet for 4 ohms said 463 watts so about 115 on each channel - perfect for my needs.
Also was able to take some pictures of my molex connectors for my doors. Probably will have to either drill through to molex connectors or push my wire through next to them...
I used this little type-c otg camera to get some tricky pictures
Also got some pictures of the engine bay side of my power wires if anyone was wondering about the space you have in there for more wire
The weather has put this on hold for now sadly
