Karkov Posted July 15, 2018 Report Posted July 15, 2018 1 hour ago, brocc said: Can I gain match my amps using a voltmeter? No. O-scope or DD-1 or DD-1+ 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
Markous Posted July 15, 2018 Report Posted July 15, 2018 You'd want a CC-1 for gain matching. '07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I On 5/21/2015 at 7:07 PM, boom50cal said: of course he gives no fucks. it's a ford ranger. only bad mother fuckers drive ford rangers
Joshdashef Posted July 16, 2018 Report Posted July 16, 2018 I've heard of people using little speakers and some other parts wired up to the speaker outputs of an amp for gain setting, but not sure if that would help with gain matching... Better off buying a tool and doing it the right way the first way. SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
reedal Posted July 16, 2018 Report Posted July 16, 2018 yes, you can. assuming both amps gains are set properly for clean output, you would measure the output voltage of both while playing a tone, and use the lower reading amp as your base, and then match the other amp to that output voltage. VAC. CC-1 does provide gain matching capabilities along with setting crossovers. both of which can be done successfully with a volt meter and tones, but made simpler with CC-1. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Rich Schenk Posted July 16, 2018 Report Posted July 16, 2018 First find max clean output for head unit with dd-1. Then check each amp individually for max clean output with dd-1 and multimeter. Write down each one. Set all amps your trying to gain match to lowest amp clean output voltage. Double check to make sure all amps have clean output voltage and your good to go. Just redid my 2 dc5ks mine is 67.2. Gl On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
will77530 Posted July 17, 2018 Report Posted July 17, 2018 Hell yea you can play a tone measure the ac output of amp 1 then set amp 2 to that same number insuggeat disconnecting subs for this no this is not how you set gains for a clean signal but will do just fine for gain matching
