Cheap lithium batteries.
I want to go lithium im really only at 16-18k burps at best but music will probably be around 12 or 13k. i think i will go with the single limitless 100ah and my single 320a alt. and my 230F bamk of super caps. maybe it isn't a lot of capacity but so long as it can put out a lot of current due to its low internal resistance i think ill be fine. Ill take my fluke and measure the max voltage drop during peaks and then ill know.
  • 4 weeks later...
i have experience with lithium batteries  , once they heat up thats all she wrote , . they literally drain out  if they heat up,  so a 16kw system i cant say it would be a bad buy  just buy what you feel, theirs ' a first for everything.
 i for one use Capacitor banks. i have a 150 Farad capacitor bank i just purchased a ton of smaller units like
 https://www.ebay.com/itm/16V-20F-Ultracapacitor-Engine-Battery-Starter-Booster-Car-Super-Capacitor-new/323282929630?hash=item4b452a07de:m:muND5G9QkUYfHbusydy3t5g:rk:8:pf:0
 And they do  exactly what i need.   Forget buying those stupid 200$ 1 farad capacitors these ones are where all the power is at .
Please post pics. of your set up
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Kilofarads or gtfo
IG @walledsonic
this is my setup. I plan on redoing this  because i mean look at it .
the Boxes are  kinda jank, kinda embarrassed showing the amplifier box BUT i agree it looks bad , but it sounds good. i took quality time setting gains  and tuning the processor   I  can set it to a comforting 20 volume  or 40 if i want to hear it 4 houses down. with the doors shut.
id much rather not take pictures of a bare speakerbox  so i got a somewhat blueprint of what i did   Towers being around 2.6 sq'ft and the big box being 2.9 sq'ft
 But  there you go.
 But now that this is out the way i plan on making a Shadowbox for this  using New 1/2" MDF led strip behind amps  to light it up And i will redo wiring  Zip ties n stuff  make it fancy adding a acrylic facing with the speaker terminals sticking out the top the layout will be Somewhat the same  but i will add fans for cooling the power converters that way i dont have a hotbox.
  • Who's Online   2 Members, 0 Anonymous, 819 Guests (See full list)
