Noobs truck box build, dual 15s, midConsole
06RTCharger
4 hours ago, White Lightning said:
Nice !!!
Please tell me that you have talked to Ray about the “feed back” circuit on the 4.1 and you know that you will need to run that amplifier as close to 8 ohms as possible.
Very nice Amplifiers !!!
No i havent. I remember asking someone on here about it. About it having 4 speaker terminals but its mono. Mightve been you lol not sure tho but i picked the 4.1 up a while ago. My subs are dual4ohms so if i run two ill run it in series/parallel for 4ohm load. If i go with a single then ill run it at 8ohm.
1 hour ago, will77530 said:
Is that regular plywood?
Not sure, i assume it is cuz it seemed cheap at lowes. $27 for a 4x4 sheet. I got to lowes late and they were closing so i grabbed whatever looked decent and cheap that was in a managable size already also because they wouldnt cut anything that late.
Feedback positive, mono positive / mono negative, feedback negative
you will make Power at 4 ohms with no problems, 8 ohms is optimal for that particular amplifier.
30 minutes ago, bcbrassard said:
Price of wood in HI is fuckin expensive! $27 for a full sheet even here in alaska.
I paid 60 a sheet for what went in the Avalanche
21 minutes ago, BassMunky said:
What brand amps? Why never MDF or Baltic birchwood? Where are you located?
Linear Power Amplifiers
Well this is a good practice box then
ideally you want a dense wood
what your using is a is a soft wood that will have a ton of voids in it
Yah for my final box im gonna use Baltic Birch. Theres a lumber store here and they only sell it in 5x5 sheets. Its like $55 for the 3/4 thick sheets.
Old school Linear Power amps. I didnt wanna deal with the fine dust of mdf and the high contents of bad chemicals in mdf. My final box will be Baltic birch, this is my test box so i got the cheap stuff to test.
Located in hawaii.
  • Who's Online   0 Members, 0 Anonymous, 1847 Guests (See full list)
