Wiring two duel 4ohm to a final 2 ohm load
Toon
Only way to get 2 ohm load is to wire a single dual 4 ohm subwoofer down to 2 ohms
2 hours ago, DiBo said:
No you cannot. 1ohm or 4.
Absolutely
56 minutes ago, realflow100 said:
run the subs with only one set of terminals hooked up on each sub. but be careful on how much power you give them because they are only running on one coil each
not recommended
Seriously ???
not recommended
Don’t do this if anything run one sub
1 hour ago, ToNasty said:
Haha its a dual coil sub so there must be 2 coils bro
So you’re telling me you can Power a sub when your are plugged up to one side of a dual coil transducer ???
Sure but you have to cross the parralel marzel veigns to the input of the parametric fans
  • Who's Online   0 Members, 0 Anonymous, 1946 Guests (See full list)
