Edit
Been out of the audio seen for at least 5-6 years, and there’s been a few changes, I was yep I’ll grab another sa series but then seen the new U series and x arnt much more now we have a local dealer
Amp is kx800.1 so does between 8-900rms
just trying to work out what’s going to be better/control on that rms?
Biggest box I can fit 4cuft net 32hz 68sqin port, so controlling the sub is imperative to be musical
u15, u18 and x15 ported
(u18 is out of stock for 3-4months as I’m in Australia) everything else in stock
also can’t go bigger on amp or this would be easy
Edited by john253a
I had that amp, it's birth sheet was 958 watts. Great amp, the shocc feature really helped out with some of the tracks that were lacking bass. I'd say just don't have your sub rated over the amp. Better to have a little too much power than not enough. You can always dial it back
1 hour ago, CstrokerV said:
With that power Would of been better with an sa
Yea SA for sure. I just purchased 2x U-12's. They need more than 1500 watts each
I’m starting here this a bit now, my local dealer thinks it will be fine, but after speaking to sundown direct they suggest the sa line and possible even waiting for the sa18 if I have the space
not because I don’t have the power, I just won’t get any excision differences between the sa and u on that power
where as I will have the power to use the sa18,
now i wondering do I wait 4-5 months for the sa18 or push my electric system and try run a clean 1200rms amp, I have no hope powering anything over that
as at current I have a kx400.2, 400.4 kx800.1
front stage is 600rms 2 sets 6.5” kicker cs comps on kx400.2 and kicker 1x crt8” on kx400.4
Rear door kicker cs 6.5 coaxel (on 50rms ea on kx400.4)
55 minutes ago, CstrokerV said:
Wouldn’t waste buying a U with only 1200 watts
Sa15= $590 to my door
  u15= $649 to my door
thats less then $60 difference,
my prices arnt like yours In USA 250vs350
100 extra on 250 is a lot 60 ontop 590
isnt
even the sa v’s the x series is only $120
Edited by john253a
  • Who's Online   1 Member, 0 Anonymous, 166 Guests (See full list)
