meade916 Posted December 29, 2019 Report Posted December 29, 2019 Look what i got for Christmas! WOW!! thank you so much Tony and Juan!!! The A1500.4 is a True Dual Stereo Design providing better stereo separation and imaging as compared to traditional stereo amplifiers - the chassis being the only thing common between channels. In an effort to provide the very best signal to noise ratio and lowest distortion possible, 109 dB (A-weighted) and <0.027% THD+N the amplifier utilizes a Mirror Image Design with positive and negative output signals of each channel generated using identically mirrored circuitry. Each of the two channels is also a mirror image of the other. A1500.4 operates the current amplifier devices in class A/B operation and the voltage amplifier devices in pure balanced Class A mode offering a realism and truth to the source never before available from a mobile power amplifier. From a design standpoint, the A1500.4 utilizes separate PCBs for the voltage amplification stage (and each of the 4 channels has its own) and current amplification stage to maximize the signal to noise ratio so that it's dead silent. It has been designed from the ground up around the highest quality components available at any cost, including; Nichicon Fine Gold capacitors, Nichicon Muse audio capacitors, (8) On-Semiconductor complementary bipolar junction transistors per channel, and non-inductive resistors, all assembled on 4-layer heavy copper PCBs! Its dual stereo channels can be wired as two single channels with double the output voltage for applications where high power is required. Finally, it includes two pair of gorgeous LED output meters to indicate actual amplifier power for each of the 4 channels as well being used for self diagnostics during a fault condition. Total continuous sine output power > 2000 Watts RMS Input Signal Reproduction Accuracy > 99.973% Meets or Exceeds Japanese Hi-Res Audio Standards Industry Standardized Power Ratings > 325 Watts Continuous X 4 into 4 14.4 VDC, 1kHz Sine, < 1% THD > 500 Watts Continuous X 4 into 2 All channels driven > 1000 Watts Continuous X 2 into 4 BTL D’Amore Engineering Power Ratings > 250 Watts Continuous X 4 into 4 12.6 VDC, 1kHz Sine, <0.05% THD > 375 Watts Continuous X 4 into 2 All channels driven > 750 Watts Continuous X 2 into 4 BTL Music Power Ratings > 400 Watts X 4 into 4 IHF-202 Dynamic Standard > 750 Watts X 4 into 2 14.4 VDC 1kHz < 1% THD > 1500 Watts X 2 into 4 BTL Quality of Signal Reproduction / Other Electrical Measurements All measurements at 12.6 V, 4 ohms, 1 kHz sine, 1⁄2 power unless specified otherwise Frequency Response Flatness from 10 – 40,000 Hz +/- 0.3 dB Frequency Response +0, - 1dB 7 – 80,000 Hz Frequency Response +0, -3dB 3 – > 100,000 Hz Signal to Noise ratio at full rated power > 109 dB A weighted Damping Factor, 20Hz > 700 Total Harmonic Distortion < 0.027% Channel Separation (1/2), (3/4), (1/3), (2/4) < 80 dB, 80 dB, 100 dB, 100 dB Max idle current 3 Amperes X 2 Max current (sine wave) 42rated power 70 Amperes X 2, 120 Amperes X 2 Efficiency at industry standard power rating, 4 65% Efficiency at hard clipping, 4 > 75% Operating DC Voltage range 10.0 V – 15.8 V Input Sensitivity, balanced/unbalanced 400 mV – 8 V / 200 mV – 4 V Input Impedance 10 k Slew rate > 30 V/S Technologies Mirror Image circuit board design – Identical performance from every output channel Dual Stereo-block design – One power supply for every 2 output channels Low EMI radiation design – for use in high end automobiles with sensitive onboard electronics Class A/B – emitter follower design with Class A voltage amplifier, Class A/B current amplifier Calibrated LED Meters – monitor the output signal vs the high voltage power supply for accurate feedback of how close to clipping the output signal is at any load impedance. Also used for indication of Over-voltage, Under-voltage, Over-current, and Over-temperature protection system activations TI / Burr Brown Balanced Input - For lowest noise and hiss Internal, independent balanced / unbalanced input switches for each channel Dual differential Voltage Amplifier Stage - For lowest distortion and very high slew rate Bi-Polar junction output transistors - For best sound quality and dependability N-Channel MOSFET Switching Power Supply - For best efficiency and high power density Nichicon Fine Gold and MUSE Audio grade capacitors in critical locations Aluminum Oxide Ceramic heatsink isolators for maximum heat transfer into heatsinks Non-inductive feedback loop for high performance at high frequencies 4-layer heavy copper main PCBs and voltage amplifier PCBs Voltage amplifiers mounted perpendicular to current amplifiers on their own 4-layer circuit boards to minimize noise Protection systems Real time analog output device monitor - 2 slope limiting system for overload protection (lower than recommended impedance or short circuit conditions) Atmel microprocessor control and monitoring of critical systems via high speed 10-bit Analog to Digital converters Battery voltage - For under-voltage and over-voltage conditions Remote Turn on request 4 precision temperature sensors, each heatsink individually monitored Output current, output voltage Power supply high voltage section Power supply PWM controller LED Display Meters Cooling Fan PWM speed control Connectors Dual 0 AWG SWWS power and ground, one per stereo-block 8 – 18 AWG SWWS speaker connectors Dual 12 – 20 AWG SWWS remote turn-on connectors, one per stereo-block Recommended Fusing 150 A fuse recommended per Stereo-block, not included, external Mechanical Base plate machined from 190 mil thick (4.8mm) 6061 aluminum, clear anodized Heatsinks, 4 pieces CNC machined 6061 aluminum blocks, not cast, clear anodized Top Cover, steel sheet metal, powder coated Dimensions, inches / millimeters 23.25 x 11.0 x 2.25 / 590 x 280 x 57 Weight, Lbs / kg 27.8 / 12.6 Get Second Skin’s #1 Sound Deadener here http://www.secondskinaudio.com Support these videos here! http://www.patreon.com/meade916 Also, check out my other pages: Instagram: http://www.instagram.com/meade916 Facebook Page here:https://www.facebook.com/SMD-Steve-Meade-Designs-OFFICIAL-Fan-Page-207890963429/ Follow: http://www.twitter.com/meade916 Visit Sonic Electronix at http://www.sonicelectronix.com 1 Quote All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
XSVTOYZ Posted December 29, 2019 Report Posted December 29, 2019 (edited) that is a beast!! Edited December 29, 2019 by XSVTOYZ Quote
CstrokerV Posted December 29, 2019 Report Posted December 29, 2019 Nice... I’m saving for one or two of his T series lol Quote my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
ToNasty Posted December 29, 2019 Report Posted December 29, 2019 13 minutes ago, CstrokerV said: Nice... I’m saving for one or two of his T series lol Does anyone even know the price of those yet? Quote ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Jessica Posted December 29, 2019 Report Posted December 29, 2019 The fact that those are 12.5v ratings is insane. Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
AaronT Posted December 29, 2019 Report Posted December 29, 2019 (edited) So it's a revised t15k? Edited December 29, 2019 by AaronT Quote
Jessica Posted December 30, 2019 Report Posted December 30, 2019 1 hour ago, AaronT said: So it's a revised t15k? No. T15k was a lot different. Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
CstrokerV Posted December 30, 2019 Report Posted December 30, 2019 (edited) 7 hours ago, ToNasty said: Does anyone even know the price of those yet? The T300.2 is 599 only one I know the price of Edited December 30, 2019 by CstrokerV Quote my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
Mohawk Warrior Posted February 16, 2020 Report Posted February 16, 2020 (edited) For some reason this clip came to my mind Edited February 16, 2020 by Mohawk Warrior Quote
LindaOmar Posted December 21, 2022 Report Posted December 21, 2022 (edited) Wow, that's a fantastic gift you got, congrats! When I want to make a cool and heartwarming gift for my loved ones, I usually go to places like jetgiftbaskets.com and pick the most interesting and delicious-looking basket, but what you got is pretty good too, lol. A lot more expensive, though, but I'm sure it's worth the money. This beast is a great achievement for mobile audio amplification and a huge advancement compared to the competition. I also really appreciate your reviews on other things and look forward to the next videos. Edited December 23, 2022 by LindaOmar Quote
