Need amp suggestions
NickJaymz
Hey guys!
So I went from kicker comps to these...
http://www.qpowerinc.com/details.aspx?product_id=160
In a nice big ol box. Now all I have right now is a jl audio 500/1 amp, and I know it's nowhere enough power cause it cuts out to loud. Of course. Now in looking for an amp suggestion on what I should get to push these things. They sound great when I have them going to where they won't cut off, but if it gets to loud it clicks off. Which is understandable.
So any suggestions that are pocket friendly and not cost an arm and leg, would be great. Something decent but cheap for now will do until I can spend the extra cash and get something more pricey!
Thanks guys 😁
Is it cutting out because you have the subs wired too low?  Under powering a sub won't cause the amp to cut off, thermal or short will cut amp off also. Budget friendly amps with decent power are the Rockville db and phenom monoblocks, have had luck with a few soundstream mono also but kind of sketchy choice there. The ppi black ice mono amps are good bang for your buck too. If you are gonna buy an amp I'd really suggest getting one you can keep using when u upgrade your subs again tho. Put good money into an amp and it'll pay for itself by not dying on you, cheap is usually just that, cheap lol.
12 minutes ago, Kyblack76 said:
Amp shutting off, cuz to loud? Interesting. I'd be looking at other potential issues. That 500/1 jl amp is a nice nice amp. Imho.
That's what I was thinking, I didn't see it was a jl 500, plenty of power for those qpower subs (if not too much honestly ) maybe coil messing up on one of the subs, had a buddy with a mofo 12 that would send amp into protect only when it hit a real low note ( like 30hz and subsonic was at 28), finally cut sub apart and bottom of vc was dinged up
28 minutes ago, Kyblack76 said:
On 1/12/2020 at 4:28 PM, NickJaymz said:
Hey guys!
Thanks guys <img src=">
Yeah uhhh could be a lot of things why it cuts out bad ground is one... from my expereince with thier amps  good luck with those subs..,
Two dual 4 ohm subs can only wire to 1,4 and 16 ohms, dual 2 ohm is .5,2 and 8 I think..his links shows 4 ohm dvc subs but how many does he have? Didn't get specific
Picture yourselves guys, when you first were doing this. He means when he cranks it up hard to floss his tunes a bit it cuts out.
1st clue
He posted 2 dual 4 subs, I will have to bet he's running them at 1 ohm.
2nd clue
Says amp can't be no where near enough, I'm assuming again he's basing this off the Q Powers inflated RMS specs and grossly exaggerated peak specs.  He is thinking based on info given to him, no fault of his own, that the subs want 900 RMS and 3400 peak. JL being small physical size as well as one of thier mid wattage models, he's damn sure it's way to underpowering them.
3rd clue.
Now based on all this facts we gathered from his posts and reasonable educated assumptions, he's got the amp way high, if not all the way to the right, in an attempt to get every drop of juice it has to the subs
Ok, OP, those subs specs are incredibly inflated.
To claim 3400 watts to the pair as peak handling, is bonkers. They couldn't take half that and not melt. 450 RMS each is even over the top. If I had to guess I'd say that's a 175-250 RMS sub.snd if one must have a be peak wattage, then I'd say they were 350-500 watts peak.
Your amp is plenty for them. Your amp is shutting off because of thermal or heat issues due to 1 of these possible reasons or all of them.
That amp is 2 ohm stable , your giving it to low impedance
          And/or
Your gain is maxed out,
  • Who's Online   0 Members, 0 Anonymous, 4736 Guests (See full list)
