Crankit89 Posted March 13, 2020 Report Share Posted March 13, 2020 Looking for recommendations on 6.5 coaxial door speakers. I'll be powering them by a stinger 700x4. Its rated 4ohm 125watts I believe. Also I have (2) American bass 12 xfls running on on a skar 2000.1 rp at 1 ohm. So I need some mids and highs to keel up with that. Link to comment Share on other sites More sharing options...
AaronT Posted March 13, 2020 Report Share Posted March 13, 2020 My recommendation for coaxials is always going to be Rockford fosgate power series T1652 Basically it's a Rockford T1650-s 6.5" component set with Tweeter mounted on a bridge, it's not connected through a "coaxial" poke piece. Same mid woofer and sane Tweeter as the component set and the crossover network is stuffed into the basket near the motor (that's why even though the mid woofer is the same one from the component set, it looks "beefier" or "deeper") I had the same set, loved them, they take more than rated, I had mine in a t600-2 as long as it's clean and eq dialed in, they take tons of power. Link to comment Share on other sites More sharing options...
slowfkncar Posted March 13, 2020 Report Share Posted March 13, 2020 Another suggestion, Image dynamic id65, those are pretty dang loud for a pair of $100$ coax, 90db/w & are smooth sounding, if you prefer brighter treble, the t1 coax is a better choice. Link to comment Share on other sites More sharing options...
Crankit89 Posted March 14, 2020 Author Report Share Posted March 14, 2020 Thanks guys any info on mmatts 601 Link to comment Share on other sites More sharing options...
BassMunky Posted March 14, 2020 Report Share Posted March 14, 2020 Go mid pro way better sound Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
MrSkippyJ Posted March 14, 2020 Report Share Posted March 14, 2020 2 hours ago, BassMunky said: Go mid pro way better sound Maybe to you. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
AaronT Posted March 14, 2020 Report Share Posted March 14, 2020 Pa sounds screeching like a cat raping a cockatoo. He's looking fir coaxials anyway Link to comment Share on other sites More sharing options...
ehall8702 Posted March 14, 2020 Report Share Posted March 14, 2020 I've had great lick with the infinity speakers , even the Primus series handle 80rms and sound very good , I had the reference components on 110 watts and they held up very well too and sounded great, just couldn't keep up with 4 8s on 3k so went with 4 pioneer pro 6.5s and 2 pioneer pro 4" tweeters. Unlike every other pro audio stuff these are very smooth and clear, definitely not a "cat raping a cockatoo" LMAO but that is a good description of most pa stuff . 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz Link to comment Share on other sites More sharing options...
ToNasty Posted March 14, 2020 Report Share Posted March 14, 2020 Wattage doesn't matter. Just pick a set you like and go with it. Dont worry about rms wattage ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
AaronT Posted March 15, 2020 Report Share Posted March 15, 2020 16 hours ago, ehall8702 said: I've had great lick with the infinity speakers , even the Primus series handle 80rms and sound very good , I had the reference components on 110 watts and they held up very well too and sounded great, just couldn't keep up with 4 8s on 3k so went with 4 pioneer pro 6.5s and 2 pioneer pro 4" tweeters. Unlike every other pro audio stuff these are very smooth and clear, definitely not a "cat raping a cockatoo" LMAO but that is a good description of most pa stuff . What 4 8s you got? Link to comment Share on other sites More sharing options...
