Extreme Groundpounder Build Up. Got Steel?(new Pics/doors Started 10-23-2k8)
just a question.
Is there any reason your using round tubing, and not square?
I am using both, square stock for the main framing and round for fill.
Round is Stronger and cheaper and as long as I align it all up before I weld its still flat to screw wood to.
Square .090 1-1/4 is 25 dollars a stick ( 20') round 1" schd 40 is 8 dollars a stcik ( 21') I buy the round from my work.
ok I have been going at it since 8am, time for a small coffee break, here are some pics to keep you happy untill later.
so I first cutt up a bunch of round steel with this ( Rigid 300 pipe threader/cutter)
Posted Image
last nite I stopped here becuase of the rian.
Posted Image
well its sunny and nippley, so away we go.
Posted Image
Got Steel?
Posted Image
Posted Image
in the pile of steel you'll notice longer pieces for the top, it wont be as solid as the bottom, but thats ok I think its gonna be plenty strong enough.
Damn thats gonna be strong! i bet its slow tedious work though.
yeah its slow, cut to fit, and I still have to do some welding on the back side of all of this to make sure it stays in place from both sides.
once I am satisfied with the rear wall, I will grind some welds on the face to make sure everything lays flat. then on to the roof and floor sections.
the sides are gonna be the hardest, I need to save myself enough roof to get to the top nut on the rear airstruts and still get my disired air space.
with a quick gustimate of known measurements I have about 25 cubes to play with, I wanted 30.
Coming along but you have got a long way to go. Can't wait to see the finished product.
2000 Ford Explorer XLT
-20" RVM "Buck" Wheels
-2.5% Tint
-CompuStar Vizion Alarm
-(4) Infinity Kappa 680.7cs 5x7"
-1 XStatic BatCap Model 300
-2 18" DC LVL 4's
-Amps are undecided
yeah its not gonna be a cheap project either way.
I just ran through the last roll of wire, so Im done for the day here is some more pics
Posted Image
Posted Image
this is the trunk side I needed it welded to to keep it super strong.
Posted Image
Posted Image
  • Who's Online   1 Member, 0 Anonymous, 473 Guests (See full list)
