Krice420 Posted September 2, 2008 Report Posted September 2, 2008 hey im having problems getting my sundowns to strap so im running 2 fully loaded btl 18's off one saz3000 at 2 ohms. each is only seeing around 900 watts and i can smell them. someone said because they are new you will smell them for a while. is this correct? also i know its hot outside here in nc but my magnets are getting warm to the point where you can still touch them but they are pretty warm. is this normal as well and expessially off only 900 watts a piece i figured they should stay just a little warm. i feel the heat blowing out the port though. any advice would be much appreciated. oh btw gains were set with a 50hz tone and a dmm. i even bumped it down 1 volt to be on the safe side. 2 18'' fi btls fully loaded 2 sundown saz 3000d 1 iraggi 200 amp alt 3 powermaster 3100d series batts 11.75 cuft wall after displacement tuned to 31.08 hz
Decaf Posted September 2, 2008 Report Posted September 2, 2008 mo powa maybe... cant move enough to cool itself whats the problem with getting them strapped? in that small of a box they are not going to want to move without more wattage
NoFearX18 Posted September 2, 2008 Report Posted September 2, 2008 mine gets a little warm but never smelly. mines was only getting like 1200 if that and its fine. My Videos AQ + AA/Fi FTMFW!!!!!
iamamp3pimp Posted September 2, 2008 Report Posted September 2, 2008 check the wiring, if its out of phase, or if one is wired totally wrong, it will do that ive never heard of the motor getting hot under normal conditions though. (2008) Florida State Champion Bass Race 140-149.9 (2008) Florida State Champion Bass Boxing Middleweight Class
audiofanaticz Posted September 2, 2008 Report Posted September 2, 2008 mo powa maybe... cant move enough to cool itself whats the problem with getting them strapped? in that small of a box they are not going to want to move without more wattage x2, subs are air cooled, with the induction of air through the magnet every time the sub moves in and out, if the subs not moving, it aint cooling. What kind of problems are you encountering with strapping the amps? If your runnning both subs off one amp at 2 ohms, Im guessing your subs are dual 2 ohm coils. So if you cant get the sundowns to perform properly strapped why dont you run 1 amp per sub at 1 ohm, instead of running 2 subs to 1 amp at 2 ohms. This makes no sense to me when you have 2 amps. Lol Did you follow the sundown tutorial how to strap the amps? Its a little different then normal class d's but its the same thing (only difference is how you connect the rca cord for strapping). Please read this tutorial on *** for strapping your sundown amps. ***there is a main problem with some stinger and monster rca cords not being compaitable with the sundown amps*** That right their maybe your problem with strapping. Ive ran into the same thing before with other amps and would really like to know why this is. http://www.soundsolutionsaudio.com/forum/i...?showtopic=7406
Team Nemesis-DJ Posted September 2, 2008 Report Posted September 2, 2008 feel free to call me ...pm me your number i can help you .....
Frozenbritches Posted September 2, 2008 Report Posted September 2, 2008 Yeah if those subs are stiff and just barely moving they aren't doing anything to cool themselves...Cease and desist until you can get more power to them... 2002 Jeep Grand Cherokee Laredo Hifonics Brutus Bxi2607D (FRIED...saving for ZX2500.1) 2 15" 07 L7's ported at 32hz Xplod POS for the MIDS, which are Memphis
missinglink Posted September 3, 2008 Report Posted September 3, 2008 wiring or pushing the amp to clip will cause (stink-a-dige-anious-ramafacation)effects on any sub. (its a werd promiss) LOL Thank yooou, thank you very much, MLA missinglinkaudio The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
roscoe1129 Posted September 3, 2008 Report Posted September 3, 2008 wiring or pushing the amp to clip will cause (stink-a-dige-anious-ramafacation)effects on any sub. (its a werd promiss) LOL Thank yooou, thank you very much, MLA who cares if its a word or not Im still trying to figure out how to say it oh yeah and its sig worthy! Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
Nightshade Posted September 3, 2008 Report Posted September 3, 2008 Depending where you are in NC I could give you a hand too. I'm in Greensboro so I don't know if that's close to you or not. I would do as Audiofanatics said and just run one sub per amp and forget about strapping the amps. You can match the amps by setting them to the same output voltage since o-scopes are super hard to come by. Let me know if you want any help and I will gladly lend you a hand if you are with in a reasonable distance. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
