RF T20001bd :8)
A little north of my budget! :P
IF I upgrade, it won't be until after tax return time! Probably end up with Hifonics amps that will bridge into 4 ohms. 1x 1200 watt amp per side, and a 4 channel amp for mids/tweets.
Is Class D significantly more efficient that A/B???
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
class d almost always has a higher effeciency than an a/b, but now theres like hybrid classes and digital amps, something like alpine pdx's are crazy effecient.
idkwhat your pricerange is, but i gotta post my amp of choice up here, 1200rms at 4ohms http://www.sonicelectronix.com/item_12249_JBL+GTO14001.html and jsut shy of 400 bux apiece
Team DC
IF
hell ya it is.....in a major way.
Follow my Tweet (Twitter)
You could strap two Sundown 1500's on that 2 ohm load.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
I am thinking 2x Crunch GP2500D, they are supposed to be ~1250 watts RMS.
I need to learn more about how to rate efficiency and look at other comparable amps to this one, but you guys know I am a Hifonics addict.
Dude I would not go with GP I have a multiple 1st place vehicle and was running GP2350 on a single sub and sucked. As far a what amp to go with check out Soundstream's new TRX amps. I am sponsored by Soundstream and have a complete Soundstream vehicle, but also check out US Amps, Cactus sound, TREO, or even HiFOnics (and yes I know HiFonics is the same company as Crunch, but HiFonics makes a higher quality amp). Remember the higher the ohms the less the distortion, 4 ohm better than 2 ohm. That is the biggest advantage to two seperate amps or one single amp.
Team Soundstream
Team Optima
Team HK
2 Soundstream SPLX-152HX
2 Soundtsream TRX2000D
1 Soundstream RUB4.600
4 Soundstream SST65
4 Soundstream TWS.3
1 Soundstream S-Cell400
1 Soundstream Power Plant
1 Soundstream BX-15
1 VMAX CT1900
2 Optima Yellow Top D34/78
1 Kenwood KDC-X493
i think ease of install would be the biggest factor...also once installed, the ease of set-up would also come into play. Gain matching multiple sub amps can be a pain (unless its RF T-series blah blah blah :D :D).
anyway you get what im tryin to say im sure :)
I put a big vote for one amp.
Why fight the probblems that come along with multi-amp applications.
If you can get an amp big enough and the rite ohm load to it, you will thank us later. Trust Me! ;)
Edited by ISO
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Running two seperate amps will help with your impedence rise. If you wire all the subs together and run them off of one amp your rise is going to be greater than if you wired half of the subs up to one amp and half up to the other.
For example, I have 2 Nightshade 12's off of a Crunch GP Pro 3000D and the subs are dual 1's. I have each coil on the subs series and then the subs are wired parallel at the amp. The amp reads 1.2 ohms at the inputs. When I figure in the impedence rise after dividing the amps voltage by the amps current I get 3.88 ohms. This means that when I am playing a test tone or music my amp is only putting out power at almost 4 ohms. So, I am only getting 1900 watts to the subs instead of 3000. I am going to get two Sundown SAZ1500D's and wire each sub at .5 ohms which would be the coils in parallel. So that when I get my box rise in the amps will more than likely be playing at 1.5-2 ohms if they carry the same trend as the subs wired to one amp.
Do you see what I'm saying about spreading the rise out between two amps? You do that so each amp has a rise, but it's not as great as it would be if you were wired to a single amp.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
I'd actually prefer to run two seperate amps for the subs, like I am now, just more powerful, without having to add more electrical support.
If anything I will probably end up moving back to the Hifonics line from Crunch.
Edited by ptcary
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
  • Who's Online   0 Members, 0 Anonymous, 7220 Guests (See full list)
