If you are going to water cool, you need to water cool the internals, not the case.
The internal heat transfers to the outter casing through convection. I'll be cooling the outer case. I'm not going to say this is going to keep the amp ice cold to the touch, but every little bit might help. Shit, it was 96degrees here today in the ATL area, just listening to the radio at near regular volume, makes my MD3D slightly warm to the touch. So with cooling the outside shell of the amp, it will at least stay as close to ambient temp as possible, which in turn should keep the internal parts that touch the outter shell, cooler as well.
I love my staffie :good:
So anti FACEBOOK it isn't even funny
we have a watercooled bazooka amp in my electronics class that we fixed.
DC.jpgDC POWER
You can also look into Thermoelectric plates.
The exchange at the amps is pretty straight forward. Cooling the fluid to a useful temp will be the bulk of the design.
Good luck with the build.
Peltiers for the win, it's not like you have a shortage of high-current 12vdc on hand ;)
Watercooling the outside of amps is inefficient. And you have the wrong term above, head is CONDUCTED not CONVECTED from the inside of the amp.
To put it in PC terms, what you're proposing is kinda like having a huge aluminium heatsink sitting on your CPU and then attaching a waterblock to the side of it. It's inefficient because your heat goes silicon -> heatspreader -> heatsink -> waterblock -> water -> radiator -> air
Currently it just goes silicon -> heatspreader -> heatsink -> air
I'm not saying it won't be cooler but the huge number of relatively poor thermal junctions will make it suck. You would be better off machining channels in the heatsink and using that as the waterblock.
Even better, you could do away with the heatsink and machine your own custom copper waterblocks that you screw the transistors directly to. THAT would be properly badass. While you're at it you could even lap the transistors for better cooling :)
Also I don't think having rads in the glove box would work - you're talking 2 very very long runs of tubing (flow fail) and a pretty crappy place for the rad. I'd put it in front of the port for added cooling :lol: :hairtrick:
Edited by Boon
10.x volts fo' life!
dam that will be sweet if you can pull it off
new system in the works
(3) DC lvl 4xls 15's (one of three are here)
(2) DD z1 (done)
old kenwood four ch
4 runs of 2/0 (done)
? 200 amp alt may two ??
Some great ideas there boon, thanks. I know the tubing run was VERY long, The D5 can typically compensate for about 11-13 feet due to its head pressure. I am going to draw this all out here and when done, i'll post it up.
Ive asked this question before. i think someone said that amps work best around room temp, im not sure on that though.
But I think it would be badass :D
Edited by finkster
Eclipse cd7000
