Do you have to connect up both voice coils on a dvc sub. please explain!!!
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
no... no you don't HAVE to.
But not using both coils is like getting a dually truck where one tire on each side is 2 inches shorter then the other. pointless.
YES both must be wired together or you WILL mess your coils up look it up on rockfords web site how to wire your dvc subs the way you should to get the maxium output
Vehicles
93 blazer
99 cavi
big 3
2 re mt 12s
custom box 4cft 40htz
soild audio 1200 wired at .5 ohms
projects
93 s10 blazer
small bock
needing finshed
or running only 2 tires on the back insted of 4
Vehicles
93 blazer
99 cavi
big 3
2 re mt 12s
projects
93 s10 blazer
small bock
needing finshed
OK, this is one of those topics like "is a capacitor better than a battery?"
There are two sides to this argument - and people can argue that running one coil is fine as long as you drop the power accordingly. There are other people who will argue that it will destroy the sub in a matter of seconds.
You can run one coil on a sub, but like the dually reply, it would be kind of like buying a viper and only driving 45 mph. I never have ran 1 coil on any of my subs and never will, but I have seen it done plenty of times with varried results.
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
if it was meant to have a single voice coil it would come that way. lol
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Sorry, but this reply is wrong.
You can connect just one. Power handling is cut down, and the t/s parameters can be varied by leaving the second coil open vs. shorting it. It is not going to hurt the sub.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Took the words right out of my mouth
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
When running only one coil, say coil #1 do you have to connect the + to the - on coil number #2 while its not being used? Or does it matter?
Derp.
  • Who's Online   0 Members, 1 Anonymous (See full list)
