6 Crossfire 18s Hummer RE-RE-RE-RE-BUILD
beyma tweeters...cp22s..107db. Trying to get 30 in there.
Your my hero :D
I think my ears may actually bleed next time I get to sit in your ride.
I will have something new in my truck next time we get together. My amp ordeal is about to come to an end very soon Bro.
Thats what my wife said when she found all the shit in the garage, she never goes in there. Cant wait to order the subs, whatever they are. How is the birch I want to do mine in some but never used it. :popcorn:
I wish every body had beat so I wouldnt have to turn my shit down. Fosgate for life running there shit since I was 16 going on 15 years strong. Not stopping any time soon.
ok. first for monkey...
the wires are ran through the factory boot going into the doors. (the red wires were there, I'm thinking they are for windows or locks. or both...)
here they are going into the kick panel from the back...
going into the kick to the boot...
coming through the boot into the door...
side panels started... first the outside piece...
router out the center for the plexi to fit into and trim it (this is 3/4" birch with 1" plexi sandwiched between)
router work can get dusty...
plexi was test fit...
next the center layer that also supports the plexi...
then the final layer was added...
thick and solid as a brick...
side panels in and back corners are started...
back panels getting secured. they are all double layer and 2x4 backed for extra strength...
fiberglass fill all the countersunk screw holes...
fiberglass reinforced body filler is some stroooong stuff... almost like concrete when its fully cured. This was added to the corners on the back wall, giving it extra strength, as well as helping to round the inside corners...
next is a lot of sanding, then some finish body filler, magic mix, then...
Ok here is a little old school for ya..
Did anyone have one of these
Maybe I missed it, but how many cubes is that enclosure and are you tuning around 28 or?
Looks great so far, nice job!
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
I still have my Merlin, and it works too! I don't use it, just sayin.
97 Maxima SE
Bunch of shit going in, check out the build
