Grounds to my tahoe's frame....quick Q for the PRO's please...
Please no one take offense to this, but I really want a reply from people WHO KNOW THE ANSWER, not "maybe" :pardon: ..
Basically my issue is ground loop noise that i've been battling for a little while. Long story short, I have 2 grounds going directly to my tahoes frame (on drivers) each run is grounded to separate bolts but they are right next to each other. Would it be better to run both those grounds to the same bolt/nut setup, would that maybe take away some of my ground loop noise? or did I do it right by having both grounds to their own bolt/nut setup?
I love my staffie :good:
So anti FACEBOOK it isn't even funny
The fewer the grounding points the lower the chance for noise to present itself into your audio system.
"Generally ground loop connection exists when an electrical system is connected through more than one way to the electrical ground. To prevent ground loops, all signal grounds need to go to one common point and when two grounding points cannot be avoided, one side must isolate the signal and grounds from the other."
Read this.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Read this.
ok, so if im understanding that right, I need to put those 2 grounds to 1 bolt then....right? Thanks for the link bro...
yes. its typically best to ground to the same point to prevent ground noise
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
Resistance between those points is probably 0.000001 ohms. Doesn't make a difference as long as each bolt is done properly.
Ground loops come from the signal side of things 99% of the time - bad RCA ground or bad headunit ground is such a common one.
10.x volts fo' life!
Chevy is notorious for this.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Meh, I just run straight ground from front battery to rear batteries.
But the 2 separate grounding locations next to each other shouldnt cause any issues at all!
Do you have any rca's near a power wire, such as by your amp rack, or crossing over a battery?
Even shielded rca's will get bad noise running over a power wire. I know I had to be very careful on my layout with the high amps mounted right above the batteries or I had noise.
i would check for that ^^^^^
and try grounding your rca's at all endpoints (headunit, eq, amp, etc)
usually you can take a lil 14g wire and touch from the rca to a grounded point
do it with the noise present (system playing) and ground all the endpoints until you find one that eliminates the noise
Newls you may want to take some time and check your factory grounds as well.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 978 Guests (See full list)
