Friends first build- Mods needed to 1200 watts rms.
My Friend is building his first system and I was wanting to know if he would need any electrical mods to support a AQ1200 amp ?
atleast the big 3 and a optima red top batt in the front
Introduce a no fat chicks in the whip rule.
Im gonna have tech force make up a sign that says that and put it on my car lol
I would do big three, new starter, and a batt in the back
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Whenever you are looking at installing an amp just look at the max draw, look at the stock alt, and then plan accordingly. In this case the amp's max draw is 120a so find out what his factory alt is and go from there. More than likely he will just need a yellow top up front with some 1/0 for the 3.
pecifications
Model AQ1200D
Frequency Response 20Hz—250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz—200Hz
Subsonic Crossover Range 10Hz—50Hz
Input Sensitivity 0.2V—8V
Output Master / Input Slave Connection Yes
Working Voltage 8V—16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 40Amp X 3 (Linked 240 Amp)
Output Power 14.4V @ 1% THD 510X1 @ 4 ohm,
870X1 @ 2 ohm,
1200X1 @1 ohm
Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm
Dash Mounted Remote Included
Dimensions 12.75″(L)x9.27″(W)x2.35″(H)
Edited by UnderLoK
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
2 270a Mechman Alts
With the big 3 , you only want to do it once...... go with the 1/0 if there is EVER a chance that he will upgrade in the future. 4ga will be better than stock but it mught choke off upgrade potential
Does this smell funny to you? Its your sister :roflmao:
I just installed my aq 1200 with a stock 80 amp alt, stock batt, and big 3 done in 1/0 and I don't drop below 13. The amp is very efficient.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Why a new starter?, OP- BIG 3 in 0ga, 0ga ran from front to back and atleast a deep cycle up front if u got the money throw one in back. Alot of people run XS i dont unfortunatly i got a YT optima up front. If he ever decides to upgrade beyond what hes looking at then a new alt would be a must have.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Under Construction for 2017
he meant a new battery under the hood. that is the first step.
and this bugs me, so im going to say it
THE BIG 3 IS NOT NEEDED UNLESS A HIGH OUTPUT ALTERNATOR IS RUNNING IN YOUR SYSTEM
you guys are passing along info that you "heard" but you have no concept on how electricity works.
MY recommendation for your friends system is upgraded battery under the hood. if he has a lot of voltage drop and issues of that nature, then he should upgrade his alternator to compensate for the amperage draw.
Edited by J00bles
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
