MECHMAN Posted August 9, 2010 Report Posted August 9, 2010 Well, I've already done a build log on the Incriminator 21" DP install, so I though I would post one up of the engine build for a change. The new motor is going to be a 383 cubic inch Windsor based engine with a MASSIVE turbo. The old motor almost broke the 700 hp mark, but a lifter failure ruined the cam and a couple other parts. The new HP goal will be 800+ horsepower at 25 pounds of boost. For those of you who don't know, this car is street driven, and also does 150 db+ @ 30 hz. If MECA would ever get it together to hold another Boom and Zoom event, I'm pretty sure it would set a world record for ET + SPL score. Anyhow- enjoy!! Here's a vid of it with the Old setup: http://www.youtube.com/watch?v=e-kE5AXOD1w&feature=related Here's the start of the new build log: http://www.youtube.com/watch?v=DBELtlZTjIw&feature=related Some random Pictures of the goodies: 1-888-MECHMAN www.Mechman.com [email protected]
OrionStang Posted August 9, 2010 Report Posted August 9, 2010 What brand and size turbo is that? Im looking at a setup for my '10. SMD Super Seller My Feedback Thread
jeyrapboy Posted August 9, 2010 Report Posted August 9, 2010 I have always had a thing for mustangs and jeeps... Yours is lookin good man.
wL<3bass Posted August 9, 2010 Report Posted August 9, 2010 What brand and size turbo is that? Im looking at a setup for my '10. Looks alot like a BorgWarner S400 model of turbo, like an S475... Hard to tell without any specs. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
MECHMAN Posted August 9, 2010 Author Report Posted August 9, 2010 Looks alot like a BorgWarner S400 model of turbo, like an S475... Hard to tell without any specs. It is an S400 series, but it will be getting the new billet race cover from bulls eye performance. It will flow a little more air at higher rpms, and should support close to 1000 hp. (not that I will be making that much) The main caps already show signs of walking, and that was only on a conservative 600 hp tuneup. 1-888-MECHMAN www.Mechman.com [email protected]
rusty959 Posted August 9, 2010 Report Posted August 9, 2010 Very nice, im tuned in. 2013 Subaru BRZ12" Orion HCCA on AQ 22001967 mustang restoration project: http://www.stevemeadedesigns.com/board/topic/110765-mustang-restoration-build-2011-edition/ Youtube: https://www.youtube.com/user/therusty959
wL<3bass Posted August 10, 2010 Report Posted August 10, 2010 It is an S400 series, but it will be getting the new billet race cover from bulls eye performance. It will flow a little more air at higher rpms, and should support close to 1000 hp. (not that I will be making that much) The main caps already show signs of walking, and that was only on a conservative 600 hp tuneup. Hmmm looks as if I was pretty close then, the S475 looks identical as far as hotside, center section, and compressor cover... The S475 is rated for 550-1050hp. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
MECHMAN Posted August 10, 2010 Author Report Posted August 10, 2010 Hmmm looks as if I was pretty close then, the S475 looks identical as far as hotside, center section, and compressor cover... The S475 is rated for 550-1050hp. The S475 with the standard cover and 1.32 AR hotside will really only support about 850 hp in stock form, as the compressor won't flow quite enough air on an engine this size at 7,000 rpm. The race cover just opens things up a little more, but leaves the same compressor wheel in place. It's mainly made for racing classes that are limited to a 75 mm turbo. Quick update vid : http://www.youtube.com/watch?v=gOiJJ2Lco5g 1-888-MECHMAN www.Mechman.com [email protected]
LT.Smoke Posted August 10, 2010 Report Posted August 10, 2010 Wow thats vicious bro. Keep up the good work. i have a high horsepower 03 Termi Cobra that i use as my Police Car Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
TeejayBee Posted August 10, 2010 Report Posted August 10, 2010 i didnt read alot but theres a guy i work with has a mustang with 1000hp and he drag races it. has slicks on the back big fawkin tires
