kickass audio Posted August 12, 2010 Author Report Posted August 12, 2010 you gotta factor in power loss through the lines, impedance rise and much more so you may want to get the coils changed over to a lower impedance...its better to have too much power and back down than try to make up for power by cranking the gains. much easier on the amp and more efficient on your electrical system. also you gotta make sure the box is right to handle that kind of power and wont hurt the sub if its tuned too high to cause bottoming out ok, well heres how i figured the least amount of power loss. 1/0 gauge power and ground all around, 8 gauge speaker wire, and the box is 3 cubes tuned to 30-35Hz (it was a prefab but its strong as hell plus has 3/4 mdf!!) i dont hear the woofer bottoming out but i can hear it distort like all hell when i really turn it up and since the amp is under-rated for the woofer that has to be letting a bad signal get to the sub. plus i didnt (still dont) have an oscope to use to really check if the signal is clipping or not. i only went by what my dmm was telling me which i know for a fact isnt 100% for setting the gains up. Anyways thats what ive done so far. im going to probably wait until i buy my dads tahoe from him and start off with another batt, then get the aq amp and finish it off with the irragi alt. Thanks again for all your help Chode, you are very helpful with everything and you know damn near everything!!! if you lived near me, id be pestering you on a daily basis to know all the things you do. haha 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
flashlight_65 Posted August 12, 2010 Report Posted August 12, 2010 After playing with one for my buddys car I can tell you it's one of if not the best built amps I've worked with and the customer service is great My builds: my caddy my 'hoe friends impala
kickass audio Posted August 12, 2010 Author Report Posted August 12, 2010 After playing with one for my buddys car I can tell you it's one of if not the best built amps I've worked with and the customer service is great thanks, im really starting to get toward buying the amp. i havent heard anything bad about it, only a few people saying its not the greatest out there but from the specs, even my co-worker who was an installer for 5 years said it was great. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
deepsilencer Posted August 12, 2010 Report Posted August 12, 2010 Hello everybody, Im looking to get a new amp to power my 12" Kicker SoloX i own. I will be replacing a Precision Power PC2350 amp and i was recommended an Audio AQ3500 d.1 from a few users on this forum. My question is for those who own this amp.... 1.) Is this amp really great sounding? 2.) What size batt and alt do you have for running this beast? 3.) What did you hook the speaker up to (resistance level)? (NOTE: my kicker solox is a dual 4 ohm coil so i can only drop it as low as 2 ohms in parallel) Any help please get back at me. Thanks once again i have one right now running my 2 12s ascendant audio mayhems there 5,000watts and 2,500rms each this amp pushes them really loud, a 295 amp alternator is recommended for that amp, to satisfy it better invest on a good alt than burn your amp or the sub i had the amp running to my old stock 160 alt and luckily i had no problems,but better invest a good ass alt, i would recommend you that,who knows if i fkd up something already and haven't noticed it yet lol 300 would do i got a custom made 300+ amps alt from mechman,did 319 amps @ 1800 rpm engine speed @ the dyno, thats perfect for my install,a 320 alt is just perfect to be in the safe side, i got screens and other electrical aftermarket units installed in my ride check out my member build got pics and specs about it on both units TEAM FLEX ISSUES,TEAM DC AUDIO 2000 Silverado Ext 1500 v.3 (Walled Silverado) 4 DC Power 270a Alts on A DC Power Quad Alt Bracket XS Power VCM,Stinger Volt Meters 4 AA Mayhem 18s 2 DC Audio 9.0ks Strapped 1 DC Audio 175.4 4 Selenium 6.5s & 4 Selenium 8s 4 Selenium Super Tweeter st350s 72 SQ Ft Of Stinger Roadkill Expert Alpine CDA 9887 XS Power d3400(Hood),6 XS Power d3100s(Bed) & much more..... 2011 Meca CA State Champion & State Record Holder In M5 Meca SPL:158.2 Meca P&P:137.4 DB Drag:159.1 USACI:161.2 BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
kickass audio Posted August 12, 2010 Author Report Posted August 12, 2010 i have one right now running my 2 12s ascendant audio mayhems there 5,000watts and 2,500rms each this amp pushes them really loud, a 295 amp alternator is recommended for that amp, to satisfy it better invest on a good alt than burn your amp or the sub i had the amp running to my old stock 160 alt and luckily i had no problems,but better invest a good ass alt, i would recommend you that,who knows if i fkd up something already and haven't noticed it yet lol 300 would do i got a custom made 300+ amps alt from mechman,did 319 amps @ 1800 rpm engine speed @ the dyno, thats perfect for my install,a 320 alt is just perfect to be in the safe side, i got screens and other electrical aftermarket units installed in my ride check out my member build got pics and specs about it on both units Hey, thats great to hear that you too like the amp. what level resistance are you at (ohms)? im going to do 2 ohms on mine. i see no need to do 1 or less espically since it takes like 98% power straight from your batt and sounds like crap to run it that low (at least in my opinion i dont really favor it) And this is toward boomin...i will more than likely get another solox in the near future so thats the only reason im not buying the kicker amp. im just that lazy 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
R_Mac_1 Posted August 13, 2010 Report Posted August 13, 2010 thanks, im really starting to get toward buying the amp. i havent heard anything bad about it, only a few people saying its not the greatest out there but from the specs, even my co-worker who was an installer for 5 years said it was great. Probably not the best amp out there, but for the money you won't do much better. I've never used the amp personally, but there are plenty people on the boards that will tell you AQ is great stuff for what you pay. 2002 Pontiac Bonneville SSEi Pioneer DEH-P6000UB Alpine SPX-17REF 6.5" components (active) Sundown SAX-50.4 Sundown z15 (3 cubes @ 35 hz) Sundown SAX-1200D 2006 Buick Rainier CXL AWD V8 Stock Bose system 12" Alpine Type E in aeroported box Profile AP1000M
Chode69 Posted August 13, 2010 Report Posted August 13, 2010 Thanks again for all your help Chode, you are very helpful with everything and you know damn near everything!!! if you lived near me, id be pestering you on a daily basis to know all the things you do. haha not a problem bro...also far from knowing damn near everything haha...i just generally know a good chunk about what i run...lots of research when investing money like that any other questions and ill help where i can NoFearX18 said: Nick will bang just about anything.....LMAO....pun intended On 4/13/2010 at 9:51 AM, meade916 said: i was like DAMN, Chode is hardcore! he makes james look like a friendly person LOL! trainman0978 said: I dont know who is worse with the buttholes Chode or Big P... Team Deadly Hertz / Team DC Audio / Team XS Power 2010 DC AUDIO MEMBER OF THE YEAR!!! DuckretaryFEAR THE DUCK Durangho Chodes Blowthrough Build Youtube vids Muh Wife Need DC Audio? Hit me up for pricing!!!
kickass audio Posted August 13, 2010 Author Report Posted August 13, 2010 not a problem bro...also far from knowing damn near everything haha...i just generally know a good chunk about what i run...lots of research when investing money like that any other questions and ill help where i can Ok, then ill ask you this just to see if you can answer this. I noticed that the aq3500d.1 has a dampening factor of less than 250, my amp now has one that is rated greater than 500, will this be a big difference? Plus i noticed that the thd (distortion) of the aq is 1% whereas my amp i have now is .02%, is that really going to make my solox sound like crap? Other than those 2 differences the amp is almost just like mine, it has the 24db crossovers and everything. Thanks again!! 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Chode69 Posted August 13, 2010 Report Posted August 13, 2010 Ok, then ill ask you this just to see if you can answer this. I noticed that the aq3500d.1 has a dampening factor of less than 250, my amp now has one that is rated greater than 500, will this be a big difference? Plus i noticed that the thd (distortion) of the aq is 1% whereas my amp i have now is .02%, is that really going to make my solox sound like crap? Other than those 2 differences the amp is almost just like mine, it has the 24db crossovers and everything. Thanks again!! lets see if i can answer this and not sound like a retard...damping factor has to do with THD (total harmonic distortion) when it comes to subwoofers you generally dont hear it unless its too late hence a fried coil. the higher the damping factor the better the signal is converted to clean power. so where the amp you have now will send a cleaner power but at a lower power where as the audioque will push more power but not as clean. i may be a little off so someone correct where needed but thats how i take it as when it comes to THD NoFearX18 said: Nick will bang just about anything.....LMAO....pun intended On 4/13/2010 at 9:51 AM, meade916 said: i was like DAMN, Chode is hardcore! he makes james look like a friendly person LOL! trainman0978 said: I dont know who is worse with the buttholes Chode or Big P... Team Deadly Hertz / Team DC Audio / Team XS Power 2010 DC AUDIO MEMBER OF THE YEAR!!! DuckretaryFEAR THE DUCK Durangho Chodes Blowthrough Build Youtube vids Muh Wife Need DC Audio? Hit me up for pricing!!!
mlstrass Posted August 13, 2010 Report Posted August 13, 2010 I run 8 of the original 3500's. Have run them from 2ohm each to .25ohm each. VERY solid amps for the $$$... Have several team mate running the 3500.1's. All are daily drivers that get demo'd full tilt for long periods of time. HO alt and a couple of G31 batts is what I'd recommend for a single amp.
