Im trying to do this box design by myself, and trying to tune it correctly but for some reason the Tuning Calculator is telling me i only need 2" of port length for 35hz
Well i figured since you guys are experts at this, that i should make sure its correct before i go cutting up my MDF :P
So here are my box's Outer Demensions
Height: 18"
Width: 36"
Depth: 22"
Box Volume: 6.75 Cubic Feet
Here is a sketchup i made:
I really need help figuring out the center port tuning .. Please
Edited by Chamois
2006 Saab 9-3 2.0T
For that box you should be closer to 6" for 35hz...HOWEVER, that's not nearly enough port area.
Yeah but if i add more port length, it will drop the tuning, correct?
This is what someone else told me:
7.2ft tuned to 35hz with 125" of port is pretty dang close to perfect for those subs
But how can i achieve this in a small box?
2006 Saab 9-3 2.0T
You will have a bitch load of port noise. Get more port area, no less than 90^2 inches, and than you will be able to make a longer port while still having your desired tuning fq
Edited by Tek
Ive tried to design the box myself, guess I cant fit my 2 15s considering they require like a 48x36x24 box to get them tuned correctly ..
Guess ill stick with my shitty Type R :noob:
Ill keep attempting a design, but no luck yet :P
Edited by Chamois
2006 Saab 9-3 2.0T
What are your max dimensions you can fit?
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
I think my max dimensions are about
40" wide
16" high
depth doesnt matter ** My trunk opening is only 20" wide, so if its any wider then i can slide the box in through my back seat **
2006 Saab 9-3 2.0T
if its in a trunk car its hard as hell to fit 2 15's, did one in a cavy i had to build the box inside the car. took me about 15 hours to finish. its a pain good luck tho
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
  • Who's Online   0 Members, 0 Anonymous, 2021 Guests (See full list)
