If i have 3 dvc 4 ohm subs is there any way i can get them down to a 1.3 ohm load to my 1 ohm stable amp?
Maybe wiring 2 together then adding the third and if so will it work, asking since im debating with a friend about it not being possible, but he states it is. I hope im wrong though.
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
you can only get a 2.66 ohm load with 3 4ohm dvc subs and you can achieve a 1 ohm load with 2 subs wired in parallel.
edit: you could get a 1.33 ohm load only with 3 2 ohm dvc subs
Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela.
He says you take 2 4 ohm dvc and put them in series/parallel which will give you 4 ohms, and the third you wire parallel/parallel to the speakers you have already and that will give you 1.3.
Again these are his words and weve been drinking he did compete in high school in kansas city in competition wiring stuff but let me know what this means.
  • 8 years later...
Yes you can, wire 3 coils together a achieve a 2.67 ohm load then wire the other 3 coils the same way.  Then parallel the 2-2.67 loads to achieve a final imp. Of 1.33.  Simple.
just wire it down to .67 and be done with it.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
Depends on amp not all are able to handle below rated resistance. Plus it requires more electrical
You won’t like the end results.
