DC Sound Lab
I need some help choosing an amp for the 4 LvL5 18's I'll be ordering next month. I currently have a HiFonics Maxximus from my last setup that I was gonna use but after researching it seems like that wouldnt be enough...? This will be a daily. What do you guys recommend? I'm not opposed to selling the Maxximus & getting something else. Just wanna know before I waste my time... Thanks for any help in advance!!! :good:
TEAM Fi CAR AUDIO/ TEAM CRESCENDO AUDIO
Bagged '06 Dodge Magnum R/T "WICKED WAYS"
-4 Fi SP4 18's (4th Order)
-2 Fi SSD 10's (midbass)
-4 Diamond Audio D6 Comp Sets
-1pr. Crescendo FT-1 Supertweets
-Dual Alts -6 XS Power Batts
-4 Crescendo BC3500d's (subs)
-1 Crescendo BC2000d (10's)
-1 Crescendo c1100.4 (comps)
well they are 2000 watts rms
2000x4=8000
find one two 4 or 8 amps that do that much powe.r
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Throw 4 of the Sundown 3500's or 4500's on them
2005 Lariat F-150
On 30 inch DUBS
6 Crossfire XS-V2 18's
2 Cactus 12k's, 1 Cactus 1000, 1 sundown 100.4
12 - 6.5 Crescendo mids and 4 Crescendo supertweets
SMD 340 alt, Mechman 270 alt
7 NSB 170 batterys
If the SoundDigital8000.1's go on sale get a couple of them :D or a single SoundDigital16k.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Logan beat me to it
2005 Lariat F-150
On 30 inch DUBS
7 NSB 170 batterys
I would say be a man and throw two sundown 2500s per woofer. Four at first then add four more.
Edited by TeamHT
2 aq 3500s if its not to your liking then 4 :)
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
If you had the loot, I would pm Jacob at Sundown, he might cut you a deal on multiple amps, and if you could do it before the preorder ends you'll still get a hella deal on them
2005 Lariat F-150
On 30 inch DUBS
7 NSB 170 batterys
