Hey guys,
I'm wondering, how does the Fs of a sub change after break-in? I've deduced that the break in process which results in lower, louder playing is due to a lowering of the Fs of the woofer. Can someone confirm this (or correct me if I'm wrong)? It makes sense to me because the suspension will have less tension/stiffness after break in and this would cause the cone to return to rest more slowly, at a lower Hz than it did before break-in (which is what the Fs is all about right).
My subsequent question is, If the above thought is true, how much can I expect the Fs to change after break-in? Would it be 1-2Hz, or more/less?
Please someone with knowledge help me out with this, I want to learn.
Thanks,
-TheBetterMethod
2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3
The first build>>> http://www.stevemead...-outback-build/
140.9 @ 36hz Sealed on dash!
REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
Yeah, that's the thing. The manufacturers give us the numbers based on basically fresh woofers.
So if anybody has the answers, I'm sure there are more than just a couple of us that want to know.
I'm guessing that it will go down, but not much, just a few hertz.
But I'm positive that the change would be different for every woofer. Some companys may measure it with a broken in woofer, I guess you'd just have to ask the said company.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
T-lines are tuned to what you want them to be, not to the Fs.
Many people tune to the Fs because its easy. Its not correct, its easy.
Break-in will depend on your usage habits. If you run a lot of excursion it will happen faster and you will lose latent (spider mainly) dampening capabilities. If you dont have excursion happening then break-in will take longer. Realistically break-in is mostly a myth and a non-issue, so dont worry about it.
Hammerdown... 1%
My Soundstream SPLX124 has a FS(Hz)of 29hz. I know what it means but can someone give a good detailed explanation on it because i'm still kind of confused?
Thanks!
02 Nissan Sentra
4 DD 3500g 10's
Crescendo Audio 3500 @ .5ohms
Soundstream EGA4220
Fronts German Mestreo 6.5 Component Set 110Rms
Rears RE XXX 6.5 Component Set 2ohms 220RMS
1 Dyralast Gold 1000Amp Battery
1 Vmax 2000amp Battery
DC Power Inc 270XP Amp Alternator
BIG 3 Upgraded
All 1/0AWG Setup
8 1/0 Awg Runs
The amount of hz that the Fs will drop depends on the woofer itself, every woofer has different changes in T/S parameters.
And there isn't really a true break in period, the spider will keep getting looser and looser, so Fs will keep dropping till the spider rips.
And how long you need to 'break in" depends on the user + the driver itself so giving a estimate is impossible.
Fs is just the resonant freqeuncy of the driver, like a sheet of metal has a resonant freqeuncy, the 'ting' you hear when you hit a sheet of metal.
I agree .
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I know with the Lvl 5's and XL's, the FS of the subs are about 70hz out the box, and go down to 32-35hz after the spider has fully loosened up.
  • Who's Online   2 Members, 0 Anonymous, 1294 Guests (See full list)
