I live in Iowa so it can get really fuckin cold, obviously my subs barely (if at all) hit when they are cold as they need to heat up so I was just wondering if there is any risk of harming them by still playing my music loud when they are still cold
I have the touchscreen dvd player, the screen hasnt been used in months (failed box design) and I was wondering if the screen will be completely fucked from the frigid cold when I can finally use it again
1993 Cadillac Fleetwood Brougham.
Jensen UV10 DVD HU
Two 12" Sony Xplode (temporary)
What i know, is that there is a vid on SMD, where a competitor blows cold air with a aircondition in his car, to get louder.
Must be work, one of the question was, if it be legit.
"in the abundance of water, the fool is thirsty" Bob Marley
i live in northern new hampshire where average temperature in the winter is like 0 degrees and is can regularly get down to 20 below and i bump all winter long, i havent had any problems as of yet, im not saying it definitely wont hurt your equipment as im just going by my personal experience but you should be fine.
and yes cold air makes subs louder, it is more dense then warmer air and therefore the subs can create more air pressure as far as i know, dont quote me on that though, thats what ive heard.
Edited by curtdakota
Cold air can give you more SPL (on the meter), but not be as loud to the ear. I made a topic about this last winter. Warm up the subs before slamming them in cold weather, the spiders especially don't like sub-freezing temps.
SMD Super Seller
My Feedback Thread
Where are the test results because I have come to find the exact opposite as you and its scientific fact that warmer air will create a better medium of transfer and more energy. And Colin goes up 2+ dB in warmer climates. Maybe we are all wrong though..... SCIENCE
this. there is also the issue of condensation if you don't warm them slowly. you can get moisture buildup on the VC's. water damage is bad. Same goes for your HU. especially touch screens. if you have a remote start...USE IT. if not...GET ONE. 5-10 minutes before climbing into the car will make a world of difference
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
just like if you were going for a run in the cold you have to warm up first. You cant step out the house and start sprinting. Im very gentle until the car warms up.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i agree with nate, when i get comfortable inside the car with the heat going, then i slap da bass :)
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
my buddy did that in hist justy haha to keep the gas fumes out
as well as team riprock does that to keep the inside of there extreme vehicle at a certain temp
as for cold in subs many things
if its a cheap plastic coned sub they crack very easy in winter
if you bump and get your sub nice n toasty n go inside over night come out your sub could be frozen from the condensation freezing up so you could f with it there
just let your car warm up before beating on subs
as for deck cant help ya been wondering myself
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 2157 Guests (See full list)
