uhoh_45 Posted February 28, 2011 Report Share Posted February 28, 2011 he wants a sealed off box thinking you need to fiberglass the contour of the roof and sides to make it air tight but hasn't put thought to making a square box then using exanding foam and a beauty pannel to seal it off R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
michigancapri92 Posted February 28, 2011 Report Share Posted February 28, 2011 ground up is the best way ! Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED Link to comment Share on other sites More sharing options...
TeamHT Posted February 28, 2011 Report Share Posted February 28, 2011 he wants a sealed off box thinking you need to fiberglass the contour of the roof and sides to make it air tight but hasn't put thought to making a square box then using exanding foam and a beauty pannel to seal it off I see now, I honestly did not interpret that when reading his post. I'm not even able to seal off at the top. My third amp will be mounted there =( Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
General Posted February 28, 2011 Report Share Posted February 28, 2011 (edited) You build it with wood ... Screws, and glue Oh?!? I was recommending some concrete for a stable platform, then some bricks glued with cement. example=> Edited February 28, 2011 by General ______Some people and performances are beyond words______ Chairman of the foundation "Propper-Droppers Holland" 2012 Founder of the European delegation of `Propper-Droppers' 2011 Dutch Champion EMMA SQ MultiMedia advanced 2010 European Champion EMMA SQ experienced 5 channel 2007 Dutch Champion EMMA SQ experienced 5 channel 2007 BeNeLux vice Champion dB-drag street-A 2007 Dutch vice Champion dB-drag ministreet-sedan 2004 _________________________________________ Propper Droppers is about deep, ground wobbling, elephant-and-whale stimulating Street Bass. The deep stuff. We test at different frequencies from deep, to low to snake’s belly. (Like 20Hz anyone?) Link to comment Share on other sites More sharing options...
monsterenergy93 Posted February 28, 2011 Author Report Share Posted February 28, 2011 Hey thanks, also i see people building frames out of 2x4 and then covering it with mdf, is that the smartest way? to frame it first Link to comment Share on other sites More sharing options...
dwright27 Posted February 28, 2011 Report Share Posted February 28, 2011 I was being a smart ass with my first reply. I'll throw some pics up for you within the next few days, that should help you out. 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer Link to comment Share on other sites More sharing options...
Juice0723 Posted February 28, 2011 Report Share Posted February 28, 2011 Do a blowthru be easier I would think. Then just use the accordion boot to make the seal and have a canopy or tonneau cover. Could easily secure that in the bed of the truck. But you probably use your bed if you actually use the truck how it should be used lol. One way to secure the wall is to use threaded rods. Put them straight into the metal of the truck. Current Setup Head Unit: Pioneer Premier 880PRS Subs: 2 Custom Ssackett 12's DC LVL5 Softparts Sub Amp: Crossfire VR4000D Highs Setup: 4 6.5" Powerbass 4XL'S & 2 Crescendo XST2's. Highs amp: Jbl Gto75.4ii & MB Quart ONX4.60 Electrical: XS Power D5100 & D3100 in the rear My Videos Link to comment Share on other sites More sharing options...
elastic Posted March 9, 2011 Report Share Posted March 9, 2011 i wonder how to build a wall secure enough so that you wont die of it in case of an accident. my 15 L7 build my youtube channel with lots of L7 videos Link to comment Share on other sites More sharing options...
C-Fizzy Posted March 9, 2011 Report Share Posted March 9, 2011 All-thread straight to the frame, my friend. 6 runs of 1.5" all-thread, it would be the accident that killed you, your wall would still be in place. under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy? Link to comment Share on other sites More sharing options...
n8ball2013 Posted March 9, 2011 Report Share Posted March 9, 2011 You guys are acting as if building a wall is so completely different from building "regular" enclosures. of course you're going to have extra steps to stabilize and seal off but the box is a box. And OP,what do you mean not a regular cube? Lol this if you can build a box you can do a wall Do a blowthru be easier I would think. Then just use the accordion boot to make the seal and have a canopy or tonneau cover. Could easily secure that in the bed of the truck. But you probably use your bed if you actually use the truck how it should be used lol. One way to secure the wall is to use threaded rods. Put them straight into the metal of the truck. you must be joking? easier to cut up a hole and then try to get it perfectly sealed up? you know what happens with the smallest leak? You get to rebuild. I guess we can tell who's never attempted either. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
