how do i build a wall?
he wants a sealed off box thinking you need to fiberglass the contour of the roof and sides to make it air tight
but hasn't put thought to making a square box then using exanding foam and a beauty pannel to seal it off
R.I.P!
(Nov-29-2009)
92 explorer
current build
I see now, I honestly did not interpret that when reading his post. I'm not even able to seal off at the top. My third amp will be mounted there =(
You build it with wood ... Screws, and glue
Oh?!?
I was recommending some concrete for a stable platform, then some bricks glued with cement.
example=> :peepwall:
Edited by General
______Some people and performances are beyond words______
Chairman of the foundation "Propper-Droppers Holland" 2012
Founder of the European delegation of `Propper-Droppers' 2011
Dutch Champion EMMA SQ MultiMedia advanced 2010
European Champion EMMA SQ experienced 5 channel 2007
Dutch Champion EMMA SQ experienced 5 channel 2007
BeNeLux vice Champion dB-drag street-A 2007
Dutch vice Champion dB-drag ministreet-sedan 2004
_________________________________________
Propper Droppers is about deep, ground wobbling, elephant-and-whale stimulating Street Bass.
The deep stuff. We test at different frequencies from deep, to low to snake’s belly. (Like 20Hz anyone?)
I was being a smart ass with my first reply. I'll throw some pics up for you within the next few days, that should help you out.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Do a blowthru be easier I would think. Then just use the accordion boot to make the seal and have a canopy or tonneau cover. Could easily secure that in the bed of the truck. But you probably use your bed if you actually use the truck how it should be used lol.
One way to secure the wall is to use threaded rods. Put them straight into the metal of the truck.
Current Setup
Head Unit: Pioneer Premier 880PRS
Subs: 2 Custom Ssackett 12's DC LVL5 Softparts
Sub Amp: Crossfire VR4000D
Highs Setup: 4 6.5" Powerbass 4XL'S & 2 Crescendo XST2's.
Highs amp: Jbl Gto75.4ii & MB Quart ONX4.60
Electrical: XS Power D5100 & D3100 in the rear
My Videos
All-thread straight to the frame, my friend.
6 runs of 1.5" all-thread, it would be the accident that killed you, your wall would still be in place.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
You guys are acting as if building a wall is so completely different from building "regular" enclosures. of course you're going to have extra steps to stabilize and seal off but the box is a box.
And OP,what do you mean not a regular cube? Lol
this if you can build a box you can do a wall
you must be joking? easier to cut up a hole and then try to get it perfectly sealed up? you know what happens with the smallest leak? You get to rebuild. I guess we can tell who's never attempted either.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 399 Guests (See full list)
