Im not wrong, heat does play a role in the impedance of a subwoofere, there are many characteristics of this, but increase in heat does infact change what the impedance will be
my post originally said: "you're wrong, for the most part"
but when you started rambling on about "and will cause less power to go through it, v = amps * resistence, as the resistence rises, the voltage will go down, thus the amount of watts"
I decided it was easier to just disagree with the entire post.
as the resistance rises, the voltage will (assuming the amplifier was able to run the lower impedance) stay the same, the current however will decrease.
the main case of this thread is is it safe, I would say not for a daily
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
you are wrong, voltage drops.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
you're trying to be running right?
set your amp so the output is 20volts.
connect a 2ohm speaker, the voltage will stay at around 20volts.
connect an 8ohm speaker instead, the voltage will still be 20volts, but the current will be 1/4, and so will the power.
its basic electronics.
To: Theydontwantmusic, why do u feel that its necessary to start an argument in every topic that you post in?
Pioneer 6300ub
Rockford Prime 6.5's
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
1.4 Cubic Foot Enclosure Tuned to 34 hz
Stinger 4 Gauge Wires
Hmmmm...this logic looks vaguely familiar...
So the OP asks a question and we all try to outsmart each other. Brilliant.
I'll ask it a different way . . .
How can the OP determine the actual impedance of his subwoofer system (subs, enclosure, wire, etc.) for:
1. SPL
2. Listening to music
What tools will he need to make this determination? How does he put them to work?
Maybe this would provide the OP with enough information to understand exactly what he needs to know.
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
  • Who's Online   0 Members, 0 Anonymous, 434 Guests (See full list)
