DC Sound Lab
Yes. A fuse doesn't pop the instant it reaches it's max potential. And in just a short burst you can get a lot more current through a fuse then it's rating.
Not recommending this but for example. You could take a 300amp fuse and hook it straight to battery + to - sparks are going to fly before the fuse pops. And that's a lot more damn current then 300.
Have you tried this? Because that's exactly what a fuse is designed to protect against. So it would have to be really quick contact.
quoted from bcae1.com
Fuse Opening Time:
A fuse does not blow when the current reaches its rated current. It is designed to pass its rated current without opening. A fuse will take varying times to blow under different conditions. A fuse will pass significantly more than its rated current for a very short time. It may take 10 minutes or more to blow a fuse at 25% over its rated current. The table below is an example of the specifications for a slow blow fuse. You can see that a 20 amp fuse may pass 40 amps of current for as long as 5 minutes before blowing although it probably wouldn't take a full 5 minutes to blow. The times for other fuses will be slightly different.
hmm... so maybe i could get away with fusing for a lower class & still do a 30sec full tilt run?...
just no demos... <_<
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
A fuse blows because of heat melting it. You cant heat the "wire" inside the fuse instantly enough for it to blow, so yes, shorting it out across a battery will probably be the equivalent of of shorting out an equivalent wire across the battery for a couple seconds or so, depending on fuse size of course. Obviously a larger fuse will take longer.
Original fuses go back in for demos
fuses suck IMO, i've had many people come to me with all burnt up wire and shit, fried amps cause their fuses never popped
only fuses i've ever seen pop like they should are maxi fuses
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
You should try this a few times to get a feel for it before doing a competition I would say. If you do practice make a video to show us please.
06 GP GXP
Google Nexus 7 16gb
Rockford Fosgate 3SIXTY.3
*Electrical*
DC Power 320a HP
2 - Juicebox Bananas g31
Stinger SPP2250 rear
Kinetik HC1800 side of wall
Optima Red Top front
Monster Cable 1/0, 2 runs to rear
Monster Cable 1/0 Big 3
2-Rockford Fosgate T1652S's
Rockford Fosgate T400-4
Rockford Fosgate T40001bd (4693rms @1ohm)
4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's
15.2 cubes net tuned @34hz! Walled off
DBdrag official 151.6db @46hz
GXP Build log!:GP GXP Walled
Quality is the sign of a true enthusiast!
Refs: Link to leave more: http://www.stevemead...91#entry1603091
Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0)
Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
sounds like installer error to me
x2
Also keep in mind in AS you have to play music
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
i did meca mod 3 with 2 8 0 amp fuses on a 12k
thats 160 amps of fuseing on amp that can pull a 1000 amps still did a 152.8 in testing befor it popped did a 152.0 in the lanes
yes you lil 3.5k will be fine with the 8 0 amp fuse you just gotta roll the volume
  • Who's Online   0 Members, 0 Anonymous, 6059 Guests (See full list)
