Fucking lol @ Nate.
About the alt. I took it up to my buddies garage so I'd be working out of the rain. Took the old alt out, struggled to put the new one in. Fucking struggled. The old alt was damn near impossible to wiggle out of the location, but it was even harder trying to force a larger case alt in there. But I got it in and slid the bolt through the top hole to hold it in. Spent the next hour trying to get the bottom hole to line up with the "adjustment sleeve", ended up having to loosen the sleeve from the block and move the angle up about a quarter inch til the holes aligned and i slid that bolt in. Then I had to blindly put the adjustment wingnut/bolt into the bottom bolt, which was nicely fucking rusted. Got that done. Plugged in the sensor and the power wire. Put the belt back on and got the tension right, put the power steering pump back in and put that belt on. Wired all the batteries back up and went to start the car.
Fired it up, battery light came on immediately, voltmeter wasn't sensing any charging voltage, just sitting steady at 12.7v. Then the alt started whining and humming. Not belt squeal. So I shut it off, kicked a trash can all the way across the shop, disconnected the batteries again, ripped everything back apart and installed my stock alt. It was late. I was frustrated. And I wasn't going to trust having a whining and humming alt in my car while I'm rolling down the street.
So I just need a full day to go ahead and redo the damn thing, most likely the pulleys weren't aligned correctly or something really simple. But it was already 8pm and I was in no mood to fuck with it any more.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
well now you know how to do it. I can do the duals in my truck in 20 minutes now.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I've swapped alts before, but having to maneuver that fucker in there was a PITA. When I shut the car off and threw the stock alt back in there, it took about 20 minutes lol.
Puns
Puns everywhere hahaha
Sounds like not only is Don giving it to you, but so is your Civic! Sorry for the frustrations. Hope it goes better next time! Try lubing the bolt before you slide it in next time! :roflmao:
:roflmao::rofl: Someone has definitely been paying attention in my class :good:
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
ohio gen :peepwall:
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Problem with Ohio Gen, homo? Lol at least I took the plunge and committed to buying an alt for the Civic. Trial and error, I probably just didn't double check something during the install.
sounds like a shitty, shitty time. Don't ya just hate it when there's dicks everywhere in your thread and butt and you then your car goes and messes up your whole day like that?
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
