2009 Honda Fit 30+MPG & Bass, Sundown, Skar, Pioneer, XS Power!
do werk son... does that relay have the included resistor in it to prevent the back feed ?
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
No it doesn't I went by this diagram; http://www.the12volt...ydiagram25.html
I do have a relay socket here that has a diode on it, however the wires coming out aren't correct I would have to switch one of them from pin 87A to 87. Which pins do the diode need to be on? Trying to find info on 12volt and not seeing any. Hit me up on AIM.
Retired from SPL again....
2016 IASCA Truck/Trunk 2 Champion 151.8db
2016 IASCA Truck/Trunk 2 World Record Holder
Yeah just found the info, thanks I will put this in now. :P
i think this relay has a built in diode, but I am not sure, here is a pic of the relay and box. Anyone tell me if so?
No I mean does the relay have a Diode in it already, I don't want to hook up more than necessary. If there's a diode inside it then I don't need the socket with diode I have.
Edit, looks like that means nothing so I do need to put the diode in.
if i can recall Chris I think there is.. Let me see if I can verify 100%
:ninja:
Where did you run the signal wires after you went through the center consol?i ran mine under the carpet mound between the two rear footwells and then under the back seat I was just curious if there was a better way. Clean install though. It motivated me to clean up my wires more in my 96 accord! Lol
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
