Noobie question here. I noticed that in the thread about things in car audio that annoy people, many mentioned rise and sometimes repeatedly. What is this so called rise? :shrug:
2004 Ford Mustang GTPioneer DEH-P7200HD head unitMach 460 Factory System
Cadence FXA1600.2
Cadence S2W10
Cadence 4 AWG wiring
Ported box, 2 cubes, 32 hertz
ohm rise is where the resistance of your subs increase due to the box and other factors and causes your amp to put out less power to your subs. its really not that important in a daily driver. the best way to counter box rise is to get an amp like the rockford cp amps because they put out almost the same power at 1-4 ohms
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
:drinks:
Ride Stats:
2003 Ford focus Zx3 Hatch Walled System
X1 Solo X Kicker 18" "Enclosure: 7.8 cbft, Port Firing Into a Horn, On a 90*"
X1 Rockford Fosgate 40001bd "Now a Warhorse On my dresser"
x1 0g Big 3
x1 Kinetik 2400 "x4 Kinetik 2400's"
x1 Kinetik 1800
x2 Kinetik Special Edition True Silver Battery Terminals
x20 Gold Plated 0gauge 3/8 Ring Terminals
x25 Total ft: KnuKonceptz Kable 1/0 Silver Pearl* 2500+ Strands.
x15ft KnuKonceptz 8 Gauge.
-Soon Too Be Walled
Fav Quote:
They Dont Feal Me, But They Feal Me.
Oh okay, thanks for the explanation!
Cadence FXA1600.2
Cadence S2W10
:popcorn: the way people make it out to be is what ever ohm load you wire down to,just think your actually a ohm load higher. example I'm wired to 2ohms but my amp only putting out 4ohm load. bummer :ehh:
It's a horrible event threatening to doom mankind due to global warming. Super duper cereal
Mainly it is for comp. Face it, most ppl who do daily systems dont care how much power their amps TRULY are putting out, they only care about it being loud. If being loud means clipping the shit out of their subs a daily driver sure will do that.
Now i have a daily setup in my truck since even though it gets very loud and low i dont want to compete with it, i know what my imp rise is and how much power my amps are putting out. The only reason i cared to know my impedance rise is to see if the amps i bought are actually putting out their rated power and they sure do and then some. I also used the impedance rise to ensure that even though i wired my amps strapped to eachother that i wouldnt burn them out. The reason i cared about burning them out is that both of my subwoofer amps are intended to run at a minimum load of .5 each. I have my SMD wired in parallel so it gets .5 ohms resting. If i didnt have impedance rise im sure i would have smoked my amps since i would have .25 ohms of power for each of my subwoofer amps which is dangerous if it drops lower than that. Now the good thing about rise for me is that it makes my final impedance 1.4 ohms i believe is what it came out. I know it was 1 and some odd change ohms that it rose up to. Now because of it i am losing some power that my amps can put out on the bottom end notes but i am getting a ton of power at the higher notes.
Now spl guys care about imp rise because they want to know how much power their amps are actually putting out and are always striving to get as much power as possible and have nothing wasted so that their vehicle will be as loud as possible.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
This made my head Xplod. :nea:
Cadence FXA1600.2
Cadence S2W10
Sorry bro, i get carried away sometimes. lol.
What i meant is for daily use it really isnt important, mainly people who do competing care about their impedance rise. The reason competitors care about their impedance rise is that impedance rise is similar to kinking a garden hose and trying to water something. Without the kink (no impedance rise) you are getting the maximum flow of water through the hose. Now if you kinked the hose (impedance rise) it would restrict the flow of water thus not letting you get a lot of water (output) from the hose.
And for my situation i wanted the most power i possibly could have without burning my amps up so i cared about impedance rise since i wired my sub lower than the amps were made to work at. I actually wanted to have impedance rise so that my amps wouldnt be stressed out from having to work at .25 ohms. For me, impedance rise was good for me to have, to some extent. To most, impedance rise is a pain in the ass as it is hard to predict sometimes until after your setup is made.
  • Who's Online   0 Members, 0 Anonymous, 1399 Guests (See full list)
