T line for,two twelves!!!
brent379
Use this chart to get an idea of how much cone area you have. http://www.stevemeadedesigns.com/board/topic/6819-cone-area-of-a-subwoofer/
For 2 twelves you have about 226 square inches. That's where you want your port area to be. I'd decide how deep your box will be first...for example if it is 16" deep and single baffle you have 14.5 inches possible width or your port...then 14.5 x 15.75 gets you to about 228 sq inches. This is just an example so play with these numbers until you get dimensions that will work for you.
They need to equal up to about 226sqin.
Area=length times width
226sqin= length times width, and you will have to find two factors that allow you to get that 226sqin.
I believe. I haven't slept in 30hrs so I'm not all here lol
reading the sticky on the topic makes it very easy to design and figure out the proper dimensions for a box. I'll be posting up a few sketch ups I'm thinking about doing for my own design, so be sure to check out me thread when it comes around! Good luck
masterbation is free, and even saves you money.sorry but someone had to say it
sorry, Jimmy...beat you to it (no pun intended)
LOLDON'T get a wife. Best advice I never got, and now it's too late <_<
My build: 12" DCON in a dorm room.
New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
Ok....ive been finally playin with the numbers a lil bit...i measured my twelve and from surround to surround its 11in...i got two twelves so total cone area is 190sqin..i loojed up the fs of my twelves and its 35hz..so my length would be 8ft...if i understand this corectlythe port area should be close to my total cone area of 190sqin... With port length bein 8ft=96sqin.... my port would have to be two inches wide...which ends up at 192sqin... To me a 2in port is pretty small...now all of this is based on the fact of if i did my calculations right lol. And if it is right can i lower my tuning freq to around 30hz without hurting the subs??? And alsi wats a good width for the port...4in???
Length does not factor into the port area. Stop trying to use the length.
24 inches wide by 2 inches tall only gets you 48 square inches of port.
Hammerdown... 1%
Fire subs up, port exiting to the passenger side with enough room to breathe. It should be an easy down-and-back sort of design.
no.
one of the main advantages (and large reasons why tlines are so efficient) is because it matches the front and rear waves effectively doubling the amplitude
doing what you said kinda gets rid of that.
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Ugh! Ok then sooooo then basically my port would have to be 8in wide by 24in tall by 8ft long?? Cuz 8 times 24 would be 192sqin.... Is that right????
  • Who's Online   0 Members, 0 Anonymous, 1120 Guests (See full list)
