PICS OF YOUR LATEST PURCHASE
Its pretty bad ass. My first fullsize truck. Only thing besides the audio that i want to change is the seats. Theyre just slide forward/back when u pull the handle. I want the power seats so it can tilt. The position the seat is in feels like im on a slide. Too use to the power seats in my charger lol.
Pretty sure they tilt, there should be a lever on the side of the seat somewhere.
No i mean like the bottom portion of the seat that u sit on. The back portionof the seat does lean back so u can lay back. But the bottom of the seat kinna feels sloped forward. Like as if im on a slide lol thats an exageration but that explains the point. Its not bad tho, just if i was to nitpick then thats my only issue.
That's a good looking truck. I like the front ends for some reason. I can't put my finger on why  but I like them.
  4 FI X 10
 270 CES alt
D3400/73ah lithium
 AA 3800.1
  (2) AA 75.4
On 2/24/2018 at 1:11 AM, audiofanaticz said:
BEWARE
It will only measure AC voltage, AC current, and DC voltage.
It does NOT measure DC amperage.
So if you wanted to test how much amperage is running through a power wire, test how much amperage your alternator is putting out, or test how much amperage your amp is using this meter WILL NOT work for any of those and you would need the CL800 from Klien to do that.
So if your in the market for a clamp meter, you might as well spend the extra money now on a clamp that will do the following, or else you maybe buying new down the road. Be cautious and read all the specs because every clamp meter is advertised as"AC/DC clamp meter" even when they dont measure DC current.
Must haves imo:
True RMS
Auto ranging (which most are)
AC voltage
AC amperage
DC voltage
DC amperage of at least 500 amps (more if you have a larger system)
Minimum/average/maximum auto hold (some meters will only do min, or max)
Hold button (not to be confused with the above hold features, this one will hold whatever is on the screen when you push hold)
Lighted display is also a nice feature if your in the dark, or a dark spot
Capacitance tester can also come in handy from time to time
The Craftsman Professional 73756 is a decent clamp for around $50-75 depending where you find it that checks off most on the must have list like DC Amperage, but its not the most accurate and smaller current readings and is a bit slower than a quality brand such as a fluke (but then your paying several hundreds for something with the same features). The craftsman is what Singer uses on his alt tests.
I bought this one back in 2012 for $99 but haven't used it much. The ratings says it's not too accurate.
http://www.sears.com/craftsman-professional-true-rms-ac-dc-clamp-ammeter/p-03473756000P
My order come in at my local shop. Skar RP 75.4 4 channel, Rockford Fosgate Punch 6.5 component set, Rockford Fosgate Punch 6x8 3 ways, Stinger install accessories/ dist block/ Anl holder, RCAS/ Y splitters and some wire. Will be my first time owning & installing a nice set of mids/highs powered by 4 channel rather than just the head unit. Also have a Northstar agm sms80 and some more 1/0 in route now..
