I plan on getting a RF p400-4 amp. I want to bridge it to 2ch for 200wrms x2 @4 ohm.
I want to run just a 6"woofer and super tweeter. they are both seleniums and run 8ohm
http://www.ebay.com/itm/SELENIUM-LOUD-SPEAKER-TWO-6-200W-MIDRANGE-WOOFERS-6W4P-/310361290261?pt=Car_Subwoofers_Enclosures&vxp=mtr&hash=item4842f97615
http://www.ebay.com/itm/SELENIUM-TWO-ST-200-140W-SUPER-TWEETERS-SPEAKERS-/280778669997?pt=Car_Speakers&vxp=mtr&hash=item415fb67fad
I want to use a 3 way x-over and just run woofer and tweeter ch.
http://www.ebay.com/itm/1-PAIR-3-WAY-PASSIVE-CROSSOVER-CAR-AUDIO-CRX-303-/360392363056?pt=LH_DefaultDomain_0&hash=item53e90f0c30
will this make a total of 4ohm resistance at the amp?
I want to run this off the front set of RCA outputs from my alpine HU.
im running my other coaxs off the alpine ktp445 power pack amp.
thanks
Edited by PeterAllen
99 Ford Ranger Reg Cab
h/u- alpine cde 9874
speakers- front type r, rear type s (6x8 coax)
amps- alpine ktp-445 (doors), alpine mrx-m100 (sub)
sub- Fi Q 12" high QTS and p-chamfer 8awg leads
box- sealed ~1.1cu ft box stuffed with polyfil
electrical- stock battery, explorer 140amp alt, 4awg throughout
http://www.ebay.com/...=item4842f97615
http://www.ebay.com/...=item415fb67fad
http://www.ebay.com/...=item53e90f0c30
thanks
Not sure about your particular crossover, but mine made the amp see 4.6 ohms of resistance with 2 4 ohm speakers (not really sure how that works) although yours might be different
Why not just used the crossovers on the amp?
The HP wont cross high enough for the tweeters. It would be having all freq over 500hz to the tweeter. Unless there is something else to cut those freq?
You could also determine what resistance the amp is seeing by taking a voltmeter and putting it on the ohm mode. Honestly this is a tool you should invest in if you are going to take this hobby seriously.
-Mark
Host of "CarAudioFabrication" - YouTube Car Audio Tutorial Channel
Check out my forum section here on SMD for my builds and tutorial videos!
Subscribe on YouTube: http://www.youtube.com/CarAudioFabrication
Wouldn't just adding a woofer and a tweeter make the sound extremely unbalanced?
Also that x-over is for 4ohm speaker so the x-over frequencies would be about a full octave off iirc.
So unfortunately, no it won't work :shrug:
In addition, a crossover splitting between two 8ohm speakers would still have an 8ohm nominal impedance.
they got some 8 ohm crossovers on parts express and check amazon for the seleniums i believe there alot cheaper
My link 2way
My link or just for the tweeter
Edited by 89boxchevy
89 Chevy Caprice (is under construction)
dual alts
4/0 welding cable for wire
red top under hood 3 yellow tops behind the front seat ( who needs a back seat anyways lol)
big 3 of course
Eclipse 3000
interiors are getting rebuilt now
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
I think I'm going to get an electronic crossover. Run the 6" through the sub level on the xover with the LPF @400hz then HP it on the amp at 80hz.
For the tweeters just set the xover to 5khz HPF. Seems like it'd work in my head...
active crossovers require separate amps for each crossover point/"way". it crosses the signal off before it gets to the amplifier.
so if you wanted your woofers to play everything below 3khz, the LPF on the crossover would be set to 3khz. the crossover then outputs the signal to the amp so that amp sees every frequency below 3khz.
then you'd have to have another amp for your tweeters that sees everything above 3khz.
if that makes any sense.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
so are you are going to run your 6" from 400hz down and your tweets from 5khz and up?
Edit: 6" from 400-8 0....
Edited by MrSkippyJ
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
  • Who's Online   0 Members, 0 Anonymous, 2682 Guests (See full list)
