OrionStang Posted December 27, 2011 Report Posted December 27, 2011 Well, you kinda just answered your own question. Quote SMD Super Seller My Feedback Thread
screwgreen Posted December 27, 2011 Author Report Posted December 27, 2011 but it should support a 4ohm load fine, Correct?? Quote PSI and Sundown audio FTW!! 2001 F150 crewcab Sundown z12v.2 on a sax1200d! 1/0 welding wire!
BobbyG2 Posted December 27, 2011 Report Posted December 27, 2011 Make sure that in the headunit, Subwoofer is enabled, and the Subwoofer Level is at max. Bass level should be 0. Also, check to make sure your RCA cable is in the right input, and if your Headunit has multiple Subwoofer outputs make sure it is set to the right one. Quote *New vehicle and system coming soon.*
Brandon15zzz Posted December 27, 2011 Report Posted December 27, 2011 Why are you worried about it being at half? My gains are never normally below 90%. FTW! Why don't you wire to 1 and set you gains a tad lower? Quote Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34 Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
Mac N Cheese Posted December 27, 2011 Report Posted December 27, 2011 Like said above, double check the rcas behind the headunit. Quote 2005 VW GTI 1.8T (4) Fi BTL N2 15s/ 4th order bandpass (2) Crescendo BC5500s Crescendo c1000.4 (4) Selenium 6w4p (Q logic Kicks) Crescendo FT1 tweeters 3 runs of 4/0 Too much 1/0 DC power Engineering 320 XP ~235A at idle 3 XS D3100s
EVAlonSo Posted December 27, 2011 Report Posted December 27, 2011 try a auxiliary cable to RCA and plug it into your phone and amplifier. play something for your phone as a source and see if it bumps. if it does you know the issue is behind the amplifier, and continue your troubleshoot. Quote
Skullz Posted December 27, 2011 Report Posted December 27, 2011 Your kenwood and alpine may have supported 4v input whereas the sundown may have 8v input which would be why your confusing the gain setting at. Turn your h/u up to where you normally play it at and keep turning up the gain till you can no longer get any louder once you reach that point back down a tad and you should be good to go. You may have to keep turning up and down a few times till your confident on where it stops getting louder at then just back off a bit and you should be as close to clip free as possible without a DD 1 or o-scope. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
HunterJohnson Posted December 27, 2011 Report Posted December 27, 2011 EQ time to boost your remote wire voltage and upgrade your wires so the SAZ can hit. Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
screwgreen Posted December 28, 2011 Author Report Posted December 28, 2011 got it all in again and finally got it working right. with subwoofer level at max and my amp at about 3/4 gain, she hits like 400 watts should. i cant wait until my wire gets here and then it will be seeing 1ohm. Quote PSI and Sundown audio FTW!! 2001 F150 crewcab Sundown z12v.2 on a sax1200d! 1/0 welding wire!
