Make sure that in the headunit, Subwoofer is enabled, and the Subwoofer Level is at max. Bass level should be 0. Also, check to make sure your RCA cable is in the right input, and if your Headunit has multiple Subwoofer outputs make sure it is set to the right one.
*New vehicle and system coming soon.*
Why are you worried about it being at half? My gains are never normally below 90%. FTW! Why don't you wire to 1 and set you gains a tad lower?
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
try a auxiliary cable to RCA and plug it into your phone and amplifier. play something for your phone as a source and see if it bumps. if it does you know the issue is behind the amplifier, and continue your troubleshoot.
MECP MASTER CEA208509
Proud employee of Alarms, ETC in lakeland, FL
ASE certified
2002 Tacoma:
4 RF P3 15s @ 28hz
2 RF T1500-1bdcps
2 pair Kicker QS
4 Pair RF Power 6s
3 RF p400-4
1 RF p200-2
ALP CDA-9887
Your kenwood and alpine may have supported 4v input whereas the sundown may have 8v input which would be why your confusing the gain setting at. Turn your h/u up to where you normally play it at and keep turning up the gain till you can no longer get any louder once you reach that point back down a tad and you should be good to go. You may have to keep turning up and down a few times till your confident on where it stops getting louder at then just back off a bit and you should be as close to clip free as possible without a DD 1 or o-scope.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   0 Members, 0 Anonymous, 1657 Guests (See full list)
