That's a Tough one. Are we talking less than 12"?
Let's say 12 inches but it would be 4 1/0 powers and grounds, dual inputs with dual inputs.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
i run 4 250 amp fuse's 1 at the alt,1 at the front batt,at the rear battery bank & then i fused my sub amp & when i upgrade my wiring i will have 2 fuse's per run of 0 as 1 poster said 00.1 db is worth my set up...... i have seen cars burn down from a wire snagging or rubbing .......and circuit breaker are useless after they blow 1 time and dont do well with alot of vibration i have killed lots of good and cheap breakers i like the anl fuse's my self ....it was mine i would fuse the hell our of it :shrug:
Edited by extremeauto
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
I think for someone with less knowledge, I would tell them to fuse. But you should be fine.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
I fuse everything. Its too much current not to. every run from front to back and every run from batts to amps is fused. 5 dollar fuse or 15 grand in equipment and a truck burnt down too. ill pass.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Every anl type fuse I have had melts rather than pops, and leaves a melted mess everywhere.. I was thinking circut breakers but can't find good high amp ones. All my 0gauge and 4 gauge wires have fuses except my big 3 up front.
2008 TBSS Black Granite
Alpine CDA-117
Clarion EQS746
AudioQue Supertweets @ dash
Alpine DDT-s30 @ b pillars
Alpine SPR-60c @ front doors
Alpine SPR-60 @ rear doors
Alpine PDX-f4
Second Skin DampPro
KNUkonceptz Wiring
DCpower 270amp alt
Optima YT underhood *temp
Two15DCxls
Hifonics bxi2610 *temp
saz4500 and 4 xp3000s coming soon.
the only time Ive seen an ANL fuse melt was due to a bad connection.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I dont fuse my AQ20 but my battery bank is less than 2 inches from the amp physically. My longest run is probably 24 to 30 inches tho. I bought all the fuses and fuse holder and was advised not to fuse since there so close together. I frequently check for rubbing tho and the wires are all ziptied. Would you guys reccomend fusing the wires?
2003 GMC Yukon Denali
Alpine CDA 117
Redoing Mids/Highs
4 Runs of 1/0 Knukonceptz 2+, 2-
4 Deka 9A31's in back (Stock underhood) 250 amp Alt.
AQ20K
2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
agreed,only thing i did not fuse is power wire from alt to batt.
Big Wheels Are Like G-Strings...Anyone can put them on but it don't mean they look good.....
I have my 12k fused but do not have my 4 channels fused. My thing is that you have to make sure that you use the proper amp fuses. If your amp calls for 1 300a fuse and you have dual inputs with 1 200a fuse on each then the fuses become worthless to me, the amp would see t00 much amperage before the fuses pop and you would still have the problem.
I used to but no longer use fuses after a few close calls with melted plastic fuse blocks. I just take better precautions now than i did using fuses now, plus every time you have a cut in the wire you add resistance and a possible point for problems. The biggest mistake i see people do is laying wire on engines with no loom or other protection and they're looking for a fire under the hood, which for them they had best use fuses or lose a car due to bad installation.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   0 Members, 0 Anonymous, 3218 Guests (See full list)
