A bit of black basecoat mixed with urethane clear did it for me, as for a factory look, like slamminbeats said, colorsand & buff to eliminate any texture from the surface.
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
VHT night shades worked great for me. mine are black when not lit
All you had to do was apply the VHT no clear coat or anything else? I may pick up a can and try it out but want to make sure I have everything to get it done right the first time.
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
All I did was clean them good, then sprayed. That's all I did. Some ppl put clear coats on. I might in the future. I need to lighten up the parking light section lol.
I've used Vht on about 10 different cars, brake and head lights. Wet sand with 1500 grit, tape off whatever you don't want to tint. 1-3 coats( 3 or more will be really dark and illegal in certain states). Wet sand with 2000 grit and buff with rubbing compound. Takes about 30 mins. Would suggest though after they dry from the paint, let cure for 24 hours before you wetsand and buff. Had better results for me. And the last wetsand and buff is not nessecary if you don't want to, just makes it smoother and glossier IMO.
i just finished hand sanding some tail lights. went from 220 -> 320 -> 600 -> 2000 grit. freakin' took like 3 hours before i decided they were ok. going to continue tomorrow as the sun's going down and my hands hurt.
I did VHT with no clear coat and it worked great, but I will say, clear may not be a bad thing. Mine started to fade pretty quick. Not sure if the clear would have prevented that or not.
10501650_10203332501847103_1859383749711
Blown
i use the nightshade on all of the tail light i have done. spray until its a little darker then what i want put like three coats of clears color sand and buff the shit out of them. takes time but havent gotten any complaints
i used to use regular spraypaint in my highschool days but now if i want to smoke lights i use vht nightshades. kept getting pulled over cause the spraypaint was too dark.. right now i have no tint on any of my lights but when i get my truck im going to black out everything using vht nightshades.
C-Fizzy, on 01 April 2012 - 01:06 PM, said:
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
Check out my build thread http://www.stevemead...product-page-2/
New build
http://www.stevemeadedesigns.com/board/topic/172646-punkrocks-97-civic-build/
