Is it normal to have rain inside my door?
What pathway does the rain go with these 3 holes? How exactly does the rain get out from inside?
Whichever way it wants to, usually down the outer door skin. Rain gets out through those holes lol..
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
look on the bottom of your doors see if you can see em?
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
The rain enters through the seal around your windows. They are rain tracks to help allow the rain to fall into the door and then drain out the bottom. The damp pro isnt that thick, using a very sharp or brand new utility knife will fix it up or get a hole punch and stab a hole through it to find the holes in the damp pro itself then cut it out a bit. They are usually the size of a sharpened end of a pencil or the eraser of a pencil. Sometimes they have rubber flaps on them like my Envoy does, some are just metal openings. They are on the outside lip of the door (if you open the door and push your fingers toward the outside they reside on the part of the door that goes down below the bump in your door to which the panel attaches to). Kinda like the ledge of the bottom of the door.
You could look up from the bottom of the door? you will be able to see them easily that way
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
So pissed right now. I'm going have to start driving with my front windows up everyday now (rains a lot in Oregon). I'll probably just roll down the back windows from now on.
Only in the valley
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
I just went out into my garage and looked under my door. It's all metal...
As for SMD Member "Kickass Audio", I apprecrieate the detailed advice, but I don't comprehend and going have to reread it tomorow.
My problem is, I don't want to break open that big seal because I worked too hard double layering that hole with Damp Pro. I've already used up all 30 sq/ft of my SS Damp Pro when I applied my baffle for the door speakers and added some more to my trunk lid earlier today.
Edited by moh.vze.com
possibly make a few new holes? if they are that small i dont think it would harm anything. Never even knew that those said holes existed in cars :unknw:
06 Jeep Grand Cherokee
2 DC Level4 12"
Soundstream TA1.3000d
4 RF Punch 6.5" Components
2 RF Punch 3.5" 2-ways
RF Prime 400.4D
XS Power XP950 +&-run of XScorpion 1/0 OFC My Civic Build
Basically just look at the bottom of your door, there will be like a ledge where the rubber door seal will sit against when you close the door. Right where that ledge is there is a small oval hole on them and sometimes they use rubber flaps on them to help seal them up from getting dirt and stuff in your door but they will be down there. Just take a brand new knife and cut it through the damp pro and you will be fine. Or like previously mentioned you can always drill a few new holes but i wouldnt go that route.
just find where the holes are and stick somthing sharp to go through the SS and your holes are back and unclogged
Here is the problem. I sealed off the big opening:
My only opening is through the speaker hole.
The other problem, SS Damp Pro is too thick for me to "feel for the hole".
are these pictures of your doors in particular, or ones you got off the web? If they are yours, look at the bottom right corner of the door where is comes to a point. there's one of the holes they're talking about. it looks like you didn't cover them. they only usually run where the outer door skin meets the inner.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
  • Who's Online   0 Members, 0 Anonymous, 1143 Guests (See full list)
