2010 Mustang GT Walled; It Was Fun, Time to go Fast
Damn dude! That was quick! Looks pretty brutal from the vids. And yea those fuggers were stiff, your lows might get better after they loosen up a little bit. Seems my lows have been getting better since you tuned my amp.
it might lower when you seal it off..i know when they sealed off the "maliboom" wall the first one his peak dropped quite a bit.. but every vehicle is different.. and its fresh subs so i wouldnt worry till they get some brake in time
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
You'll def get deeper when you seal off. also what's your infrasonic set at?
2007 Pacifica
lol "theres my stripper pole opening"
will you actually need a pole? didnt look like you were flexin too hard at the window
Did you see how far I still have to go on the knob? This is only the beginning.
Goddamn you guys want him to go full tilt on new subs?!? It's only gonna get louder...
um why the hell not
Ok, maybe i'm and idiot, but don't you want to go easy on new spiders? Ken does go through subs quickly....
2007 Pacifica
not really, they are going to meter loudest new most of the time anyhow.
Ive never blown a sub ever and i'll slam on stuff right out the box.
The only sub ive ever done a "breakin on" are my DD subs, and to be honest i thought it was rather silly the process they wanted me to do in order to "break in" thier subs
So why should he stop going through subs so quickly now? Haha.
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
my issue is this...
how has it not been turned up if he knows that is only a quarter of his "knob"
Either its been turned up, or his gains are probably set wrong, hence why he goes through subs. its had to have been turned up to at least know if his gains are at a safe level either clipping wise, or mechanical wise.
You guys think My peak will get higher or lower once its sealed off. So far, I am kinda disappointed in the lows.
In all honestly I believe in the wall setup in the mustang since your shrinking down the cabin of the car it always seems to me like it raises a few hz, like in a wall setup likes your could be wrong though
I had 2 xl5s in my back seats sealed off and it raised a few hz
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
What the fuck are you guys talking about me going through subs? Only sub i've blown is the lvl 6. Gains are set properly, I don't want to go full tilt until I get a second baffle on there and I want to give the fiberglass a good 24 hours to set. Has nothing to do with sub break in.
Mother fuckers should probably read everything before talkin a bunch of shit.
SMD Super Seller
My Feedback Thread
