When I drill metal I lubricate the bit and turn at a slower speed. I drilled a handful of holes in 3/16 steel the other day. It takes a while but it keeps the bit alive.
Big 3 with Yellow Top
All I know is that tacomas have shitty frames...I drilled through it no problem. Sanded it down good and secured my grounds. Was getting voltage drop down to 10v. Switched my grounds to the batts and was back up to 13.5+
where do you think those batts are grounded?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Do not drill at full speed. Use a good bit, and you should have no problems.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
The the carpet obviously.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
2 270a Mechman Alts
Seatbelt bolt?? :pardon:
Seriously though, if your battery is grounded to the frame of your truck and if your connections are good then you shouldn't see voltage drops into the 10's. Unless the frame is made of plastic :rofl:
Lol guess I'll have fun drilling my frame. Try starting with a smaller bit nd work your way up to the size you need. Sharp bits make a work of difference.
Big Wheels Are Like G-Strings...Anyone can put them on but it don't mean they look good.....
no shit.lol
  • Who's Online   1 Member, 0 Anonymous, 428 Guests (See full list)
